Puma heater switch problem!!!
Old Jul 27, 2006 | 11:35 PM
coolRST's Avatar
coolRST
Default Puma heater switch problem!!!
Has anyone here had a problem with a heater switch? as they are elecrtonic on the Ford Puma mine is constantly set to hot has no change if winded to cold, can't cope in this heat i think i'll melt
Any advice would be appreciated
Old Jul 29, 2006 | 12:03 PM
cpcossie's Avatar
cpcossie
hello mate you probably need a new mixer valve look under the bonnet and follow the coolant pipes up to and through the plastic engine bay bulkhead on the other side of that is a valve that the pipes go into with a two pin multiplug on it change that it should sort your problem
Old Jul 29, 2006 | 12:09 PM
dave_si's Avatar
dave_si
Sounds like your heater control valve mate, quite a few people have experienced this problem. Think they are about £40 for a new one from Ford, very easy to fit as well
Flatlinedan
Sep 18, 2015 12:41 PM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
marky_g
Sep 12, 2015 04:26 PM
Ben26
Sep 3, 2015 07:55 PM
