WB Lambda sensor placing
Old Jul 23, 2006 | 11:11 AM
2wd's Avatar
2wd
Default WB Lambda sensor placing
Hi...I have just got a WB AFR gauge and I am in doubt how far down the exhaust I shall place the sensor .....
What is your opinion ??
Old Jul 23, 2006 | 11:59 AM
reality's Avatar
reality
As close to the turbo as possible..most people stick it just before the bend in the downpipe..
Old Jul 23, 2006 | 05:16 PM
NEWTON's Avatar
NEWTON
yeah as above just before the bend
Old Jul 23, 2006 | 08:31 PM
Avinitlarge's Avatar
Avinitlarge
According to the instruction, If its too close to the turbo the heat from it shortens the live of the sensor, Also it has to be between 9 o'clock and 3 o'clock position, Thats only if its on a horizontal section of the exhaust though
Old Jul 24, 2006 | 06:33 PM
paconassa's Avatar
paconassa
the max operating temp is around 900ºC so after the sump is probably a good place... and least 15º from horizontal avoid condesation retetion in the sensor
Old Jul 24, 2006 | 07:27 PM
reality's Avatar
reality
I'd be a little worried if you're getting EGT's of 900C after the turbo!
Old Jul 26, 2006 | 09:11 PM
JjCoDeX75's Avatar
JjCoDeX75
I have to say that in my experience if you are running the WB for tuning, if it is too far away from the engine, the info is not quick enough. I run mine about 4 inches back from the turbo, and it has lasted a very long time.
I have a boss at the bottom of the pipe for other things, and to be honest, it isnt as good
Hope this helps
JJ
Nov 1, 2015 06:53 PM
rsguy
44
Sep 29, 2015 03:29 PM
wheelwizardrefurbs
Sep 22, 2015 05:45 PM
Si B
Sep 12, 2015 06:49 AM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
