Hi Lo Boost on Cossie
Old Dec 19, 2003 | 08:19 AM
CosRush's Avatar
CosRush
Default Hi Lo Boost on Cossie
Im aware than you can cut the Amal valve supply wire to give a switchable Hi Lo Boost control, but was wondering if anyone has ever wired it to a throttle switch, so that full boost would operate under near full throttle wheras the rest of the time it would be low.
Recon it would be good for normal day to day driving.......
Any thoughts???
Old Dec 19, 2003 | 10:03 AM
foreigneRS's Avatar
foreigneRS
Testing the future
reckon you might need it in a Rush, but in a heavy old sierra you always need full boost (except ice or snow in a 2WD)
Old Dec 19, 2003 | 10:10 AM
CosRush's Avatar
CosRush
So any idea's on the Throttle switch???
Im thinking that if i get a Make/Make switch, then the circuit would be broken up until (near full throttle posotion) when the switch would make and Full Boost would be operational........
Can you see any obvious flaws in that idea???
Old Dec 19, 2003 | 11:36 AM
You might want full boost but without being flat to the floor!
imagine a kev try's to overtake you when ur in 2nd or third, you would want full boost to piss all over him but you would be unwise to put the pedal to the metal without feeding it in first cause it could all end in tears
Plus your car will eat the gears bloody quick anyway so by the time your foot gets all the way to the bottom it will need to come up again so you can change gear.
It will be very rare on the road when you will be flat down in 1st 2nd or even 3rd depending on what spec it will be!
like i said before, mark and me have this setup but we have a arming switch on the dash or you could put it on the steering wheel
Old Dec 19, 2003 | 01:53 PM
CosRush's Avatar
CosRush
Thanks for that Darren,
I think i'll do that too.
I like the idea of it being on the wheel, so you can hold the steering wheel with the right hand whilst changing with the left (ready for orbit!!!) and then one press of the thumb and........
Old Dec 19, 2003 | 03:52 PM
CosRush's Avatar
CosRush
Can you remind me which is the wire to be switched???
Old Dec 19, 2003 | 04:09 PM
Toe Knee's Avatar
Toe Knee
Its the black/red wire going to the amal valve.
Old Dec 19, 2003 | 04:19 PM
CosRush's Avatar
CosRush
Thanks Toe Knee,
Does it make any difference how long the lengths of wire are to extend the amal switch to the inside of the car???
Old Dec 20, 2003 | 12:35 AM
Nope !!!
Old Dec 20, 2003 | 08:46 AM
CosRush's Avatar
CosRush
Thanks to all for the help
Old Dec 20, 2003 | 02:26 PM
PJay's Avatar
PJay
Just make sure you gt it checked that it's fuelling correctly on high and low boost
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Russ Payne
Sep 25, 2015 08:29 PM
