Escort S2 Pressurised...
Old Aug 12, 2004 | 07:10 AM
ldack's Avatar
ldack
Default Escort S2 Pressurised...
Just starting using my S2 that has just had full engine rebuild, pistons re-bore new cam etc.
Was pottering around in it yesterday, not going fast as running in. When turned off, you can here the coolant system, and the tank is quite pressurised. Is this common? Please help
Old Aug 12, 2004 | 07:13 AM
JesseT's Avatar
JesseT
The tank should be pressurised with a warm engine. What do you mean by hearing the cooling system?
Old Aug 12, 2004 | 07:53 AM
ldack's Avatar
ldack
you can here it bubbleing if you know what i mean, i wouldn't have been able to open the tank up or water would have come out. \but runs fine, starts ok, doesn't run hot etc.
Old Aug 12, 2004 | 08:34 AM
JesseT's Avatar
JesseT
Either you have a leak somewhere meaning that you gradually loose pressure to the point that the water starts to boil, or then you have a hot spot in the cooling system after shutting the engine (water flow stops). The most common cause of the problem is the close proximity of the turbo to the radiator.
benw456
Sep 16, 2015 05:27 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
