COSWORTH MELTED PISTON PLEASE HELP
Old May 29, 2006 | 07:13 PM
NAKRS's Avatar
NAKRS
Default COSWORTH MELTED PISTON PLEASE HELP
IVE MELTED NO 2 PISTON ON MY G REG 4X4 COSSIE
MY FAULT COZ AFTER FITTING STG3 GOODIES I WENT RACING WITHOUT SETTING THE CO;S THE CAR WAS OVER FUELING AT IDLE BUT UNDER BOOST ALL HELL BROKE LOOSE I LEFT THE OPPOSITION IN THE BUSH THOUGH, ANYWAY I NEED TO KNOW IF IT IS POSSIBLE TO REMOVE THE SUMP WITHOUT TAKING OUT THE SUBASSEMBLY AND KNOCKING THE PISTON OUT FROM THE BOTTOM IS THIS POSSIBLE BEARING IN MIND ITS A 4X4 THE TRANSFER BOX RUNS THROUGH THE SUMP.
Old May 29, 2006 | 07:26 PM
costina's Avatar
costina
Live long and prosper!!
No pistons only come out top so head needs to come off
Expensive mistake
Old May 30, 2006 | 08:30 AM
velocity's Avatar
velocity
its near on impossible to take the sump off in place best thing is to take the head off in position its handy enough t do and doesnt take long. then drop the whole engine and gearbox assembly together from under the car, after the usual disconnects its only the 4 cross member bolts and the gearbox mount that hold the lot in,
to get access to the conrod bolts and maybe a block stripdown for rebore there is going to be a fair bit of access required so you might aswell remove the complete engine
Old Jun 1, 2006 | 12:49 PM
NAKRS's Avatar
NAKRS
Default MANY THANKS
CHEERS FOR THAT INFO M8
I AM HOPING 2 ONLY REPLACE THE 1 PISTON THERE IS NO RIDGE ON THE BLOCK ONLY BITS OF ALUMINIUM SPLATTER
ONTHE SIDE SHOULD BE ABLE TO HONE IT AWAY I HOPE
I HAVE ALREADY TAKEN THE HEAD OFF ,I THOUGHT IT MIGHT BE EASIER TO DROP THE SUMP IN ORDER KNOCK THE PISTON FROM THE BOTTOM UP BUT THE SHAFT LOOK LIKE ITS RUNNING THROUGH THE TRANSFER BOX AND THE SUMP
WORSE CASE SCENARIO CAN THE CYLINDER BE RESLEEVED
Old Jun 1, 2006 | 04:34 PM
velocity's Avatar
velocity
the shaft is not the problem.you would have to support the engine block once you remove the cross member, then you have to remove the front dilff which can be done without removing the engine but again you do all that all thats left holding the engine more or less is the bell housing bolts so why not remove the whole lot and disassemble in comfort
if you need any pictures or part numbers let me know.
Old Jun 5, 2006 | 08:09 PM
NAKRS's Avatar
NAKRS
Default MANY THANKS M8 FOR THE INFO
APPRECIATE THE PICS ASWELL
Old Jun 5, 2006 | 08:26 PM
wimwerf's Avatar
wimwerf
capslock...
cossie09
Oct 11, 2015 06:29 PM
KW-rscos
11
Aug 31, 2015 01:51 PM
Escortdriver1
Aug 31, 2015 11:19 AM
ekjim
Aug 17, 2015 08:57 PM
Aug 14, 2015 07:29 AM
