Help Please - Indicators Won't work.
Old Dec 15, 2003 | 07:47 PM
MoonDustSaph's Avatar
MoonDustSaph
Default Help Please - Indicators Won't work.
Anybody got any ideas???
Escort ERST S2
The LH and RH turn signal will not work.(Indicators)
The Hazzard warning will work though, and all the indicators flash when i arm and dis-arm the alrm.
I have changed the flasher unit, and the switch unit complete. (both with new items)
I am now at a total loss.
Thanks.
Tony
Old Dec 15, 2003 | 08:43 PM
Doug's Avatar
Doug
Stupid fooking question m8 fuse is ok aint it ?
Also what alarm unit is on it have you tried bypassing the indicator feeds from the alarm as some alarms do have a tendency to short to earth
Hope this helps Doug
Old Dec 16, 2003 | 04:49 PM
MoonDustSaph
yes i have looked at the fuse and all seems ok, but i would have thought indicators and hazards go through the same fuse???
It's a Cobra alarm mate.
Old Dec 17, 2003 | 02:46 PM
Damo V's Avatar
Damo V
Dont thingk indicators and hazards use same fuse... one has a triangle the other had two small lights on it or arrows ay??
Old Dec 20, 2003 | 06:14 PM
MoonDustSaph
Took it in, in the end. Never guess what it was??????
Yep...............
A short/problem in the reverse light switch harness
dojj
Sep 29, 2015 10:32 PM
A.t.p
Sep 29, 2015 05:04 PM
Cossikev
Sep 13, 2015 02:00 PM
The Enigma
Sep 12, 2015 10:12 PM
