turbo boost t3 conv!!!
Old May 17, 2006 | 03:15 PM
dj22y's Avatar
dj22y
Default turbo boost t3 conv!!!
hiya can anyone help me!!!
bought a FSRT couple days ago and i knew bought this problem but was wondering what to do,#
when im drivin it then give it some revs when it reaches bout 4 thou in all gears it starts kangeroo'in but if you take your foot off pedal then go again boost starts then kangeroo's again!!! its had a T3 conv do you think its over boosting???
ive no ideas!!!
help!!!!!
Old May 17, 2006 | 04:59 PM
bezo's Avatar
bezo
powered by K26
over boost is coming in. stops you melting your engine.
is it chipped?
maybe running to much boost for what its set up to run?
Old May 18, 2006 | 07:52 PM
dj22y's Avatar
dj22y
ive no idea if its chipped or not!!!!!
so what should i do?????
just get it on the rollers???
but i dont wanna waste £130
Old May 18, 2006 | 09:39 PM
SafeChav's Avatar
SafeChav
Boost gauge.
The boost limiters are usually quite harsh in operation, if it is boost limit cutting in you should know about it
Old May 19, 2006 | 07:55 AM
dj22y's Avatar
dj22y
so what should i do then??? if the boost limit is kicking in does it normally kangeroo??? if i give it revs in 1st it goes then it sort of cuts power then same in all gears??? but then if i turn the enginine off for 10 secs or so its all right again till i give it some beans!!!!
will this fuck my engine??? im not flooring it anywhere till i get it sorted!!! need help!!!
Old May 19, 2006 | 12:22 PM
bezo's Avatar
bezo
powered by K26
yep thats the over boost kicking in.
like safechav says , you need a boost gauge to see what its running?
if your still on blues injectors then you might be running the risk of blowing your engine!!!!!!!!
what mods have you got?
Old May 19, 2006 | 03:10 PM
dj22y's Avatar
dj22y
just got K&N, zorst, T3 maybe chipped dunno yet!! just got a boost gauge which side do you put it on left or right of efi thingy.... think i might have blue inj!!! what should i be getting???
Old May 19, 2006 | 03:13 PM
Mr Shannon's Avatar
Mr Shannon
you'll be wanting beige's
Old May 19, 2006 | 05:12 PM
bezo's Avatar
bezo
powered by K26
iy like shannon muate say bosch 701's youll be needing
your boost pipe to the boost gauge goes on the left hand side of the inlet(as you look at it from the front of the car)
stick your head in the pass foot well and look up the back of the dash, now you should be looking at the bottom of the ECU (silver box thing), if its chipped there should be somthing pluged into the bottom of it.
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
gchristophi
Aug 31, 2015 10:36 PM
CrOwSoN15
18
Aug 22, 2015 10:24 PM
Escortdriver1
Jul 31, 2015 02:36 PM
