Escort Td
Old May 14, 2006 | 12:19 PM
Chris-S2's Avatar
Chris-S2
Default Escort Td
Hi all, i've just bought myself a W plate Escort Td for my daily runner and I think there's a problem with the heater/ac, it was cold all day yesterday and I put the heater on high and the thing would only blow luke warm, I thought maybe it would take a while to warm up with it been diesel but after an hour it was still blowing the same luke warm air and not really warming inside the car up, any ideas?
Also on the hot few days we've had i've put the air con on and that doesn't seem to blow as cold as I imagined but I just thought maybe it wasn't as good as the air con in my old car? Maybe the two are linked?
Hope someone can help,
Chris
Oh yeah one last thing, has anyone owned one of these before and what sort of milege did you get from a full tank of fuel?
Old May 14, 2006 | 12:28 PM
DazC's Avatar
DazC
IIRC the air con system is a bit of a night mare on these cars with regards to wiring.
First off, get the air con system serviced. It'll cost you in the region of Ł80 and it should be carried out annually.
With the heater, it could be possible that the thermostat is stuck open. It should be closed when cold so check that it is.
Also check that the heater matrix hasn't been bypassed as sometimes when they start to leak, people can't be arsed to repair it (then sell the car in summer)!!
Old May 14, 2006 | 06:52 PM
saffauto's Avatar
saffauto
Air con could just need re gassing mate. Also sorry if it sounds stupid but have you checked your coolant levels if that is low heater wont blow hot. good luck
Old May 14, 2006 | 07:14 PM
Chris-S2's Avatar
Chris-S2
Cheers for your input guys I've checked the levels and they're all ok so i'll get it booked in for the air con checking out asap.
Thanks ,
Chris
benw456
Sep 16, 2015 05:27 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
rogerxr3i
Sep 13, 2015 06:56 PM
bassboy
Sep 10, 2015 08:54 PM
imnoteasy
Sep 7, 2015 09:26 PM
