Bleeding coolant system...???
Old Aug 5, 2004 | 09:02 PM
CosRush's Avatar
CosRush
Default Bleeding coolant system...???
Is there a particular method for bleeding the coolant system on a Sapph 4x4?
Old Oct 11, 2004 | 11:18 PM
blaazer2's Avatar
blaazer2
no ,why do you have a prob? check the small hose where it goes into the header tank isnt blocked
Old Oct 12, 2004 | 05:14 AM
RS500/364's Avatar
RS500/364
leave the expansion tank cap off heater on full till it reachs normal temp then should be done
if you squeze the pipes while it is warminup gently should get any air in the system out
Old Oct 12, 2004 | 06:45 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Dunno if it helps, but, there's a little screw on top of the thermostat housing, I usually take it off when filling up with coolant to help air escape.
markeh
Ford Focus Diesel
Apr 11, 2016 02:15 PM
Chas
Oct 5, 2015 07:13 PM
Botts
Sep 22, 2015 02:04 PM
mk1focus
Ford Fiesta
Sep 21, 2015 05:46 PM
