Badly vibrating/shaking fez
Old May 8, 2006 | 12:56 PM
wildheart's Avatar
wildheart
Default Badly vibrating/shaking fez
Got a problem with my 94 fiesta rs1800 and no one can find what the problem is with it.
It starts to vibrate/shake the whole car (believe its from the front end) when you accelerate,but as soon as you back off the accelerator all is fine
The car does feel a bit unstable when going around tight corners etc.
It has got Deflex gearbox mounts fitted but they seem to have no movement in them at all so it looks as if they are fine.
Checked all tyres.
Its down at a mates garage now and he says the only thing he can think of now is the diff in the escort rst gearbox
Think im close to burning the thing now
Old May 8, 2006 | 01:43 PM
JohnT's Avatar
JohnT
Loose gearbox, Misfire when throttling, ???
Old May 8, 2006 | 01:47 PM
wildheart's Avatar
wildheart
No misfire
Just a very bad vibration when you floor it
Old May 8, 2006 | 05:29 PM
escortrsmatt's Avatar
escortrsmatt
possible driveshaft problem mate,get it on some minis at work.
Old May 8, 2006 | 06:57 PM
wildheart's Avatar
wildheart
Looks like its time to drop the gearbox mounts to see if the inserts have broken up if not it looks like its the driveshafts,cant see what else it could be then
Old May 8, 2006 | 09:48 PM
cossie604's Avatar
cossie604
Sounds like inner cv joints to me m8..Mondeos used to have a similar problem.
Old May 9, 2006 | 12:35 PM
wildheart's Avatar
wildheart
Cheers Stu,i'll get them checked out too
Prickly_buzz
Dec 7, 2017 09:52 PM
Fordmad!
Sep 29, 2015 07:03 PM
A.t.p
Sep 29, 2015 05:04 PM
Fordmad!
15
Sep 27, 2015 06:24 PM
