Boost protection????
Old May 7, 2006 | 12:05 PM
szabyk RST's Avatar
szabyk RST
Default Boost protection????
91' FRST
At 16psi as it reaches the 6200-6300rpm, the car slows down, rpm falls down to 5000,
and the pressute too. It exists until I step off the gaspedal.
If the pressure is higher, this symptom appears sooner:
18psi-> 6000rpm
20psi-> 5500rpm
Why does it happen?
What can I do, because i wanna use my car on 20psi?
spec:
1.6 low comp Mahle
superchips(unlimited boost)
FMIC
denso racing fuel pump
305ccm injectors
champion QC59C
T3 stage3
thanks for your help
Old May 9, 2006 | 02:39 PM
szabyk RST's Avatar
szabyk RST
Old May 9, 2006 | 02:45 PM
SafeChav's Avatar
SafeChav
If its boost cut you should feel it quite violently stop, usually a loud back fire and the rev counter will drop to 0 and then resume........and will repeat that process until you back off/reduce the boost
Old May 9, 2006 | 06:26 PM
szabyk RST's Avatar
szabyk RST
no stop.....no loud back
stand cca 5500rpm and boost down cca 0-0.1bar
Old May 9, 2006 | 08:26 PM
SafeChav's Avatar
SafeChav
Bit too technical for me there cca????
Old May 10, 2006 | 04:11 AM
szabyk RST's Avatar
szabyk RST
cca=circa
sorry
Old May 10, 2006 | 08:45 AM
SafeChav's Avatar
SafeChav
I have to say im still a bit lost
(i may have made myself appear to be more clever than i in actual fact am )
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
