FIESTA VALVE CLEARANCES
Old May 2, 2006 | 07:53 PM
zoo keeper's Avatar
zoo keeper
Default FIESTA VALVE CLEARANCES
I,ve just bought a 1996 Fiesta Encore 1.3 that is in need of the valves adjusting. i know how to adjust the valves, my problem is that i don,t know what clearance to set them at. according to my haynes manual there is two different engines for this year, the later model supposedly having a sticker on the rocker cover to identify it. The rocker cover on mine has been repainted at some point so has no sticker, the difference between the two engines is .20mm on the exhaust valves.
Any advice would be much appreciated.
Old May 5, 2006 | 08:02 PM
sexr3i's Avatar
sexr3i
isn't it
try adjusting the clearances to the larger tolerances first, then allow the engine to fully warm up. if it still clatters like a bag of nails, try the tighter tolerances. If the tighter tolerances cause it to misfire when warm, loosen em off again. Clearances are a bit of a guide really, as long as they don't hold the valve open and they aren't clattering, you should be fine.
Old May 5, 2006 | 08:09 PM
SafeChav's Avatar
SafeChav
Am i right in thinking that has a engine similar to a HCS???
Old May 5, 2006 | 08:26 PM
zoo keeper's Avatar
zoo keeper
my engine is an Endura-E petrol engine, sorry i don,t know if that is similar to an HCS engine
Old May 5, 2006 | 08:36 PM
dave green's Avatar
dave green
Inlet 0.20mm exhaust 0.30mm engine cold
Dave
Old May 5, 2006 | 09:52 PM
SafeChav's Avatar
SafeChav
I'm sure its the later version of a HCS, they all seem to tap like a slag
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
