2wd diff seals
Old May 1, 2006 | 12:22 PM
timster's Avatar
timster
Default 2wd diff seals
Hi
How hard a job are the rear diff seals?can i leave the diff in place and just unbolt the driveshafts?doing job on deck no ramp access
thanks in advance
timster
Old May 1, 2006 | 01:48 PM
cossie604's Avatar
cossie604
to remove the drive shaft diff flanges you need to remove the rear diff cover (flanges held in place by circlips internaly) and this requires the lowering of the diff. TBH its dead easy to drop the diff on the floor mate...imo its easier on the floor than on a 2 post ramp cos when you send the car up in the air, the lower arms drop down and get in the way of a couple of the diff mounting bolts. Ive changed a couple of mine on the deck and found it quicker than when i changed them at work
Old May 1, 2006 | 03:08 PM
timster's Avatar
timster
thanks for the reply cossie604,do i need to undo any of the suspension bolts as well?or will it just slide out after taking out driveshaft bolts diff side,prop bolts and securing diff bolts?
Cosnada
Jan 7, 2016 05:30 PM
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
DavidK
Sep 27, 2015 02:55 PM
