closed loop lambda control
Old Apr 29, 2006 | 08:04 PM
cozzyspud's Avatar
cozzyspud
Default closed loop lambda control
Hi there I need some info on closed loop lambda control for my 3dr cossie.I know what it does but is anyone out there using it and does it give the benefits that it is claimed to do? how much did it cost and who would you recomend supply it? many thanks.
Old Apr 29, 2006 | 08:43 PM
stevieel's Avatar
stevieel
i think stu at msd is the man to speak to, try a search if you havent done so allready, i read a great write up on here regarding this subject, has convinced me to go closed loop on my mk1 cossied escort when its finished
Ste
Old Apr 30, 2006 | 08:03 AM
foreigneRS's Avatar
foreigneRS
Testing the future
you will need a L8 ecu with std ford babyboard, as there is not enough memory in a L1 to write the code in the run program that the ecu uses.
putting a L8 ecu into a 3dr also means you need the pf09 tps to be matched with the ecu and the 2 outer wires for the tps swapped around.
if you get an L8, get back in touch and i can tell you where to have it done
hth.
Old May 1, 2006 | 10:36 AM
foreigneRS's Avatar
foreigneRS
Testing the future
the output of the lambda sensor needs to go to pin 2 of the ecu. the other 2 wires on the lambda sensor are ground and 12V power supply for the heater.
Old May 1, 2006 | 10:48 AM
need4speed00001's Avatar
need4speed00001
Will the standard l8 chip run llambda?
Old May 1, 2006 | 04:36 PM
foreigneRS's Avatar
foreigneRS
Testing the future
yes if it's from an ecu originally fitted to an engine with lambda and cats (green top late sapphire 4x4 for example).
generally, most modified chips do not run closed loop fuelling although they can be made to do so
Old May 1, 2006 | 08:16 PM
need4speed00001
thanks for your help
Old May 2, 2006 | 11:17 AM
adam rs's Avatar
adam rs
I had closed loop lambda control on my 2wd cossie.I bought the kit complete from stu at motorsport developments.I had to buy a second hand L8 ecu from a 4x4 cosworth.I took the car to motorsport developments in blackpool for a set up with stu.I covered over 240 miles on half a tank of fuel! It worked really well.I have however changed engines now so the complete kit is for sale if you are interested.It includes the chip for stage 3 (greens,3 bar etc..)modified board,daughter board for lambda,Lambda sensor and full instructions as supplied by motorsport developments.This lot cost me a pretty penny so sensible offers would be appreciated.
Old May 2, 2006 | 09:37 PM
Stu @ M Developments's Avatar
PassionFords Creator
http://www.motorsport-developments.c...closedloop.htm
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Marv888
Sep 26, 2015 03:44 PM
