closed loop mod=big mpg???
Old Apr 28, 2006 | 08:59 AM
perpetualpower's Avatar
perpetualpower
Default closed loop mod=big mpg???
Alright chaps,
Wondered if anybody could shed light on the closed loop modification that I read on here can earn you up to 38mpg on the cossies?????
That's pretty impressive if to be true??
Cheers PP.
Old Apr 28, 2006 | 09:45 AM
frog's Avatar
frog
0-60 in 17 seconds (eek)
Closed loop means the ECU is able to control fuel delivery accurately in off/low boost conditions, so yes, going around town or driving along the motorway off boost, the ECU will only deliver as much fuel as is necessary hence an increase in MPG.
It won't make any difference on boost irrc.
Old May 2, 2006 | 11:23 AM
adam rs's Avatar
adam rs
Had closed loop on my cossie 2wd.I got 38mpg easily and covered 240 miles on half a tank of fuel.Kit is for sale now due to change of plans.Kit is motorsport developments,complete with instructions.
Old May 2, 2006 | 05:43 PM
Staffi's Avatar
Staffi
38mpg i must invest
Old May 2, 2006 | 09:37 PM
Stu @ M Developments's Avatar
PassionFords Creator
http://www.motorsport-developments.c...closedloop.htm
Old May 2, 2006 | 09:55 PM
costina's Avatar
costina
Live long and prosper!!
How much Adam ?
Cheers Paul
Old May 3, 2006 | 07:12 AM
adam rs's Avatar
adam rs
Looking for 250.00 for the complete kit, including ford board ,lambda control daughter board, lambda sensor and stage 3 chip with lambda mapping.All instructions are included but you will need to contact stu at motorsport developments for a lambda boss to weld in the exhaust.You can ring me on 07762034121.
Old May 3, 2006 | 07:59 AM
foreigneRS's Avatar
foreigneRS
Testing the future
lambda control daughter board?
Old May 4, 2006 | 10:26 AM
foreigneRS's Avatar
foreigneRS
Testing the future
adam rs have you got any pictures of this stuff. i'm especially interested in the 'lambda control daughter board' as i cannot understand it.
why would you have a daughter board for that when it can be done from the eprom as in a green top L8 ecu or p8?
Old May 4, 2006 | 10:41 AM
Its simply a Software encryption key for the ECU Nick. Ive Plenty of pics knocking about if you want one mate.
Old May 4, 2006 | 10:50 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i understand now Stu, no need for pictures thanks
boeb
Jan 9, 2020 05:11 AM
Nov 1, 2015 06:53 PM
Brickhouse
14
Oct 3, 2015 07:28 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
SMILER258
Sep 28, 2015 09:04 AM
