Saph cos fueling problem......
Old Apr 20, 2006 | 07:09 PM
CosKev3's Avatar
CosKev3
Default Saph cos fueling problem......
Hi
My m8's car has developed a problem while its been off the road having some body work done
Have tried a new map sensor on it and checked the resistance of the blue temp sensor
Injectors have been flow tested/cleaned.
The car is over fueling like mad on idle sometimes,then other times its ok at 3% Co,also its running lean when on boost,we checked the plugs after a blast and they were white
Smoking a lot on the over run,grey/black smoke,but idles lovely and running fine
Any ideas please,thinking it could be ECU,anyone had probs like this before???????
Also can welding on a car damage the ECU???????
Thanks
Old Apr 20, 2006 | 07:25 PM
costina's Avatar
costina
Live long and prosper!!
Sounds like map sensor try blowing pipe out to it if this has water in it can cause over fueling
Just an idea
Old Apr 20, 2006 | 07:46 PM
nicksaph's Avatar
nicksaph
Default Re: Saph cos fueling problem......
Thanks
yes it can! but if the welding was done by a respectable garage they would have disconnected the battery or put a surge protector across the battery befor they started to weld.
Old Apr 20, 2006 | 07:48 PM
CosKev3's Avatar
CosKev3
Thanks
Have tried a new MAP sensor
Could be the welding then,perhaps the bodyshop forgot to disconnect the battery at some time,had alot of welding on it,new arches/sills etc
155lee
Oct 27, 2015 04:55 AM
Cossiesteve
Ford Escort RS Cosworth
Sep 17, 2015 12:37 PM
gcfcos
88
Sep 15, 2015 03:48 PM
dojj
28
Sep 11, 2015 10:00 PM
kevin36
Sep 8, 2015 12:23 PM
