COSWORTH HOT START & IDLE PROBLEM
Old Apr 20, 2006 | 11:06 AM
IANS2RST's Avatar
IANS2RST
Default COSWORTH HOT START & IDLE PROBLEM
my stage 3 sapphire does not like to idle when its warm some times the idle is erractic & other times it just cuts out. when it does cut out it struggles to restart.
when it cols it starts on the key but the idles is sometimes not perfect.
any ideas?
Old Apr 20, 2006 | 11:21 AM
silky16v's Avatar
silky16v
Get on That!
had this with my escos replaced ICV and fitted new inlet side gaskets cause wasn't sure if there was an air leak problem solved now
Old Apr 20, 2006 | 11:25 AM
IANS2RST's Avatar
IANS2RST
an air leak on the plenum would cause a high idle though i thought
when i disconnnect the iscv it just stalls stright away
Old Apr 20, 2006 | 03:43 PM
bud-weis's Avatar
bud-weis
Football Cwazy
adjust the idle speed so that when the iscv is removed, it runs at about 850rpm, also clean out the throttle plate area
Old Apr 20, 2006 | 03:50 PM
IANS2RST's Avatar
IANS2RST
just done that will c what its like on the way home
Old Apr 21, 2006 | 09:23 AM
IANS2RST's Avatar
IANS2RST
hot start problem is still there but it now idles fine
Old Apr 21, 2006 | 11:51 AM
Dave Henshall's Avatar
Dave Henshall
what does it do (or not do) when its hot?
does it crank, does it back fire, does it turn over slowly... what?
Old Apr 21, 2006 | 12:23 PM
IANS2RST's Avatar
IANS2RST
turns over normally, no popping or backfires.
just struggles to start which it does eventually after about 15-20 seconds of cranking
otherwise runs perfectly. when colder always fires on the key within 2 seconds
Old Apr 21, 2006 | 03:20 PM
KSA-Cossie's Avatar
KSA-Cossie
Best get it checked over m8.
Old Apr 21, 2006 | 07:46 PM
rapidcossie's Avatar
rapidcossie
coolant temp sensor on its way out
Old Apr 24, 2006 | 10:03 PM
Stu @ M Developments's Avatar
PassionFords Creator
I tend to agree with this as a best guess.
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
Aug 14, 2015 07:29 AM
Adam-M
22
Aug 10, 2015 10:46 AM
Zoggon
Aug 10, 2015 10:39 AM
fish6634
Ford KA
Aug 2, 2015 01:02 PM
