master cylinder
Old Apr 18, 2006 | 06:08 PM
madrs247's Avatar
madrs247
Default master cylinder
the brakes on my 3i are a bit crap ,so ive checked the pads discs and bleed them,but theyre still very bad,
basically when u brake the pedals rite on the floor so ur foocked if u slam on.
im gunna try the master cylinder,but cant find one any where in the breakers .
the cars a 90 h 16oo xr3i efi
is it the same as the rs??? or just for the 3i???
surely it would be the same???????
also did the 3i have abs???
ANY HELP WOULD BE GREAT
CHEERS
Old Apr 18, 2006 | 08:46 PM
costina's Avatar
costina
Live long and prosper!!
s1 should b the same but s2 has only 2 outlets so u would need to tee off for the fronts,it also has a bigger bore size of 25mm,great 4 all disc conversion as i have one on my cortina.
some late xr's had mechanical abs driven by a belt on drive shaft
Don't think it was much good
Old Apr 18, 2006 | 08:52 PM
Moondust_crust's Avatar
Moondust_crust
xr3i 1990 has a 23mm master cylinder 4 outlets, not great but better than nothing, if you can get a brand new one it will work pretty well.
Old Apr 18, 2006 | 09:07 PM
costina's Avatar
costina
Try GMS Capri spares think they have new ones
Old Apr 18, 2006 | 09:12 PM
Moondust_crust
or your local automotive dealer mate, when i bought mine it was about £83.00
hth
Old Apr 18, 2006 | 11:30 PM
SafeChav's Avatar
SafeChav
I have a very good condition 23mm if you are interested mate
Nov 1, 2015 06:53 PM
muzzman1
Sep 30, 2015 08:59 PM
