Installing guages in a saff???
Old Jul 31, 2004 | 06:40 PM
rog's Avatar
rog
Default Installing guages in a saff???
I have a later spec saff with facelift dash, i was going to get the earlier spec dash and mount 3 gauges where the heater vents are, but just wandered, do the original earlier spec saffs have heater vents there and if so what about the ducting behind it, do i just remove it or what????
Cheers!
Old Jul 31, 2004 | 07:18 PM
2001ode's Avatar
2001ode
Hi,
Remove and plug.
What do you want to install of type of gauges ?
I suggest one TC pressure, one combinated oil temp / oil pressure / fuel pressure with one inversor, and one exhaust gas temp.
What do you think about that ?
Regards
Old Jul 31, 2004 | 10:42 PM
bob s2zvh's Avatar
bob s2zvh
rog look on the nomad web ste you get heaps of different mounting plates and pods there! easier to fit them than a dash!Also guy on here does pods for your steering collum think its gaz@race-spec check the for sale signs? you getting home the morn? you should see how foggy it is up here in the brents! hope you manage to get a chopper! lucky bastard i've still got a week to go!
Old Aug 1, 2004 | 07:22 AM
rog's Avatar
rog
Nah i don't think i'll get home either, can't see a bloody thing outside!
I've already got a guage mounted on the pillar, i'll have a look and see. Cheers!
Old Aug 2, 2004 | 08:28 AM
foreigneRS's Avatar
foreigneRS
Testing the future
i had gauges mounted where the centre vents are, but after a while i put back the vents cos i prefer to have the airflow. now got a gay dash top 3 gauge mount.
if you do remove the vents, you must block the duct or outlet from the heater box, otherwise there will be less restriction here and all the airflow will just piss out behind the dash
cossie330
Sep 27, 2015 04:13 PM
ajamesc
Sep 27, 2015 02:25 PM
IainRS1700T
Sep 25, 2015 06:44 AM
