cosworth idle
Old Mar 29, 2006 | 05:27 PM
coley's Avatar
coley
Default cosworth idle
i have a problem! please help
when the car is cold it dosnt want to tick over at all,and when the car is at running temp it ticks over at about 500 rpm. is there any way i can pick the idle speed up? what is the proper idle speed? any help will be great thanks again
Old Mar 29, 2006 | 08:44 PM
bud-weis's Avatar
bud-weis
Football Cwazy
under the throttle body there is a brass screw,disconnect the iscv andundo the locknut and turn it to increase the revs to about 850rpm,then re-connect your iscv.
sounds like the idle speed control valve is playing up though, remove it and clean it out with some brake and clutch cleaner
Old Mar 30, 2006 | 10:00 AM
coley's Avatar
coley
thats great ill get on the case
many thanks for you reply
Nov 3, 2015 04:08 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
15
Oct 7, 2015 03:43 PM
Ade
Alloy wheels and ICE for sale
Sep 7, 2015 05:06 PM
