ERST Starting Probs :(
Old Mar 20, 2006 | 10:38 PM
Robmk6's Avatar
Robmk6
Default ERST Starting Probs :(
any chaps on here got any ideas as to why a freshly tuned RST engine wont start when its cold??
(when i say freshly tuned its covered less than 1k miles since Jamsport gave it a good tune up and then boost increase BUT it has been sat for 8 months, and has been run up and used for approx 12 hours over the last 2 weeks)
seems to me its not getting enough fuel to start it from cold, if i remove the air filter and hold the flat down for a second or two (with ignition on) try again and two turns and it will start fine
BTW its an S2 engine in a mk5 shell
Old Mar 20, 2006 | 10:39 PM
Robmk6's Avatar
Robmk6
oh and to add after its initially started it will start no problems at all
Old Mar 21, 2006 | 01:06 AM
SafeChav's Avatar
SafeChav
U got the cold start valve connected? If yes disconnect it and re-try, if vice versa, then try vice versa, and if still no luck, buy 1 can of unleaded, a box of matches................
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
gcfcos
88
Sep 15, 2015 03:48 PM
xrmalin
Sep 13, 2015 06:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
stevierob
Sep 7, 2015 07:09 PM
