poo in pipes on breather system - Engine breathing heavily
Update to post - we think that engine is breathing heavily. Help help. Any suggestions to likely causes?!?!
Thanks
Hi all
I recently (ish) fitted a bailey oil separator/ breather system.
It is a very basic system - pipe comes up from kidney to tank, pipe from cam cover to tank, pipe from tank to side of block, and pipe to atmosphere.
I seem to get a huge build up of the water-oil creamy mixture, which gets so bad I have to clear out the whole system by removing it and cleaning it through to prevent it clogging completely.
The oil remains clean, as does the water system, ruling out an obvious head gasket failure (and it was replaced recently).
Is this really just due to Condensation?
Has anybody else experienced this problem?
Is there any way to resolve/ diminish the problem?
Help!?!?!?!?!?!
JJ
Thanks
Hi all
Help!?!?!?!?!?!
JJ
Hi,
The car is equipped with a 200 block from esco, so I returned in the blanked plug position just above the sum on side of block (beneath exhaust manifold).
Separator appears level to the naked eye!
Thanks in advance for any thoughts?
JJ
JJ
Originally Posted by JjCoDeX75
Hi,
JJ
JJ
disconnect the vent and use a bottle to catch anyhting that comes out?
see how you go from there
Hmm - Ok, I will set that up for curiosities sake.
Any thoughts on what would cause an engine to breathe heavily? I have had other troubles with the old girl. She had a full engine rebuild (including complete bottom end rebuild - re-bore, new pistons and rings, full balancing etc.) and checked guides, new stem seals in head, and new turbo.
Even with the above, after 10k (albeit hard miles) I get smoking when the car is under load.
Is it possible that some boost is escaping past the bores, causing too much pressure in block, and causing both probs?
Thanks for your thoughts
PS - as an addendum, spoke to Bailey who were very helpful. They seemed to think that the 'mayo' of oil and water was normal this time of year, and will improve in summer months.
JJ
JJ
yeah probably mate.
there are various reasons for hevey breathing but im not competant enough to go into them i dont think.
one of the experts will be able to help
I will change the title to hopefully attract some attention!
Thanks for your assistance, and I wouldnt mind if you had a crack at what you think it would be!!
JJ
JJ
Generally, I run as a max about 24-15 psi peak, holding slightly below.
The problem is that the engine had the full rebuild only 10k ago! We had to replace the head gasket a few weeks ago, and replaced the Group A (which had failed) with a Tri-layer WRC Style Cometic Gasket.
Whilst the head was off, I had another look at the guides which seemed to be in good order. The Stem seals were new 10k ago, so I would be surprised if that caused it, which leaves me with this real poser as to why it smokes, and as a consequence why it breathes heavily.
It makes me think piston rings are causing probs, but I am struggling to believe they would fail so quickly!
If it helps, it tends to smoke first thing in the morning after boost is first applied (obvoiusly once warmed up), and then if you accelerate hard down a road - little bit of smoke to start, then when you take your foot off the gas, then re apply your foot, (even gently) a puff of grey smoke is my reward.
Any thoughts appreciated as I am on the verge of stripping the thing to pieces again.
cheers
JJ
Doh!
cheers
JJ
Doh!
rapidcossie
Thanks for your input. I do appreciate it, though I think we may have them stumped!!
In order to assist with the enquiries, I am going to take it to my local tuning chap, and perform a leak-down test to see how the piston rings are.
Hopefully this will shed light.
I still have reservations about the fuelling - just the usual signs ie very black around the exhaust, and some black smoke when cold. It seems to run very rich (though I cannot qualify this absolutely).
It is running a Bayjhoo (sorry spelling!) Stage 3 Chip which I know is a reliable chip, but I wonder if something else is buggering up the fuelling.
Any thoughts???
JJ
Any thoughts???
JJ
At least I'm not the only one!
I will let you know what I find from the leak-down test. Tell me what your spec is - it may be helpful to compare notes....
a leak down test will not always determine if rings are fook ed my engine used to pass every test going but still drank oil big time.
try and find and expert that can tell you once and for all.
cant believe no-one else has helped....
come on guys!!!
come on guys!!!
Doh - Sorry for your loss. Hopefully that will solve it, in which case could be worse!!!!
I checked my pipes, and they are clean. Also the turbo on mine is less than 12 months old, and appears to be ok (pity, cos turbo is still under warranty!!!!!)
I will post my findings after the weekend
Quick update - Performed leakdown test, and with 3 bar of air pressure (min), and achieved less than 5% leak on each cylinder!!
As such, does not appear to be piston rings (which is a relief with the bottom end rebuild only dating 10k ago!!)
So more head scratching and headaches......
JoeyBoyden
18-08-2015 10:52 PM
