saph aircon into 3dr
Old Mar 20, 2006 | 02:07 PM
kiwicossie's Avatar
kiwicossie
Default saph aircon into 3dr
Does anyone know if it's possible to fit saph aircon into a 3dr cossie.
Looking at my 3dr I can't see what the hard bits would be.
Help???
CheeRS
Old Mar 21, 2006 | 05:46 PM
opposite lock's Avatar
opposite lock
Default Re: saph aircon into 3dr
Help???
CheeRS
hi mate , i recently read on here that its not as straight forward as it seems. That was 4x4 saff air con , into a 2wd saff. the bulkhead is different apparently which makes it impossible/difficult im not sure. Im presuming the 3 door bulkhead is same as 2wd saff
Old Mar 22, 2006 | 08:01 AM
foreigneRS's Avatar
foreigneRS
Testing the future
does your 3 door have air con from the factory? if not, a factory a/c system will not fit as you don't have the large cutout in the bulkhead for the evaporator (where the blower motor is)
is the saph air con factory or aftermarket? if it's aftermarket, maybe it could fit.
Old Mar 22, 2006 | 12:06 PM
opposite lock
factory(optional extra) in 4x4 saff .
Old Mar 23, 2006 | 07:33 AM
foreigneRS's Avatar
foreigneRS
Testing the future
opposite lock
i know that it was a factory option in sapphs, but what is it that kiwicossiehas? there were also add on aftermarket kits that were designed to be fitted to non-a/c cars.
Old Mar 24, 2006 | 07:18 AM
kiwicossie's Avatar
kiwicossie
I have a 3dr and a 90 4x4.
I was thinking of fitting the air into the 3dr and using that as the family car and putting my newly built 4x4 engine in as well.
Unfortunately the baby buggy won't fit under the parcel shelf so that idea is out the window.
Will now fit air from a 91 or 92 saph into my 4x4.
I got the whole thing with compressor, evap, condensor and switches from chap in UK who stated that it had been removed professionally.
Have been led to believe that the only small inconvenience will be where the hoses come out from the heater rad.
Looking fwd to getting some cool air cos in summer the 28-30C gets a bit much.
Has anyone had grief with engine smell coming into the cabin when stopped at the lights.
Old Mar 24, 2006 | 07:51 AM
foreigneRS's Avatar
foreigneRS
Testing the future
don't think that it's that easy, but you'll see. let us know how you get on.
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
martynhomer01
Oct 1, 2015 12:05 AM
Russ Payne
Sep 25, 2015 08:29 PM
