battery voltage and bad starting
Old Mar 17, 2006 | 12:39 PM
Dave Henshall's Avatar
Dave Henshall
Default battery voltage and bad starting
i know a poor battery will not start a car verry well, but would a battery that is going dud still allow the car to crank and crank and crank with the occaiional backfire when cold.... see other post...https://passionford.com/forum/viewtopic.php?t=182567 it definately does seem worse the colder the weather is. if its been run up the motorway and you come to start it a few hours later, its 100% fine, but stood out in -2 dgc overnight and it does sound a bit slow ont he starter... the escos volt meter shows 13.5 it idel when its running, but when you switch on forst thing, the fuel pump runs, the abs pumps up and the idle valve clicks, this lot holds the needle at about 10 volts (indicated) what should it pull down to when you first ignition on,, beofre you start cranking....? i'll put a meter on the actual battery 2morrow mornign and see what its sat at ..... its a halfords HCB097, calciyummy one (albeit 3 years old) shal i treat it to a new motorcraft silver jobbie?
Old Mar 21, 2006 | 10:00 AM
Dave Henshall
fitted the new bosch silver battery today, it reads 13.2 when stood not running and 14.2 at idle now
the old one even when disconnected only read 12.2...
the in car volt meter reads a whole volt higher at tickover aswell now - perhaps the halfords one had had its day...
i have to say it does whip it over much much faster and without any backfires either
wil wait and se 2morrow, fingers crossed
Old Mar 21, 2006 | 08:11 PM
CosKev3's Avatar
CosKev3
Good luck
Easy fix if that was the prob
Old Mar 21, 2006 | 08:13 PM
rapidcossie's Avatar
rapidcossie
fingers crossed dave
Old Mar 21, 2006 | 08:33 PM
Dave Henshall
its started faultlessly 3 times now from cold, well see in the mornig after its been really cold 2nite
Old Mar 22, 2006 | 09:50 AM
Dave Henshall
again thismorning, all ok, starts stright away - it hasnt doen this for a long time, but plaiged with one thing and another... porous head, knackered starter, knackered battery
Old Mar 22, 2006 | 11:05 AM
THE RADMAN's Avatar
THE RADMAN
looking promising then
track.focus'd
Aug 12, 2015 05:53 PM
tankybaby66
Aug 9, 2015 07:13 AM
xr_craig
Aug 7, 2015 06:00 PM
Bloody-Fox
Aug 3, 2015 07:48 PM
ginger1979
Jul 31, 2015 09:56 PM
