need help, is it the adjustor
Old Mar 16, 2006 | 11:59 AM
deankenny's Avatar
deankenny
Default need help, is it the adjustor
my car jugs when i put slight pressure on the accelerator, its fine when i got my foot right down or half down maybe quarter but below quarter it jumps and jugs like its struggling, someone said could be the adjustor on the clutch what do you guys think?
Old Mar 16, 2006 | 01:02 PM
SafeChav's Avatar
SafeChav
U say uve got a problem when you accelerate less than 1/4 throttle and someone has suggested the clutch
Old Mar 16, 2006 | 01:04 PM
frog's Avatar
frog
0-60 in 17 seconds (eek)
What car is it ?
Could be throttle position sensor if you have one, they tend to wear out and the reading off them is inaccurate in some throttle position, leading the ECU not to know how much fuel to put in - hence the erratic running.
HTH
Old Mar 16, 2006 | 05:44 PM
deankenny's Avatar
deankenny
thats what i thought, how can it be related to the clutch, yes whatever hear im in it seems to not pump petrol in at that point on the accelrator, well it does but jumps really bad so i cant cruise really slow in traffic coz it just jumps, how much would it be to repair the sensors ur talkin about
Old Mar 16, 2006 | 05:45 PM
SafeChav's Avatar
SafeChav
Tell us what car it is first give us a clue
Old Mar 16, 2006 | 05:49 PM
deankenny's Avatar
deankenny
o yeh soz lol, well the engine is a 95 escort zetec engine 1.6
Old Mar 16, 2006 | 05:50 PM
SafeChav's Avatar
SafeChav
The way you worded that im presuming the engine is not in a 95 escort then no?
deankenny's Avatar
deankenny
no the engine is in a mk5 94 escort
Old Mar 16, 2006 | 05:52 PM
SafeChav's Avatar
SafeChav
Hmmmmmm well i was going to say if it was in something foreign there could any number of possibilities. Was it a like for like swap or has the car been converted?
Old Mar 16, 2006 | 05:53 PM
deankenny's Avatar
deankenny
no the engine was converted in 2001, and its only just started doing it yesterday
Old Mar 16, 2006 | 05:57 PM
SafeChav's Avatar
SafeChav
Hmmmmm see being a conversion there is so many possibilities, even harder when someone else has done the conversion simply because you don't know whats been done and what hasn't. I'm not really up on Zetec managment either haven't really come into contact with it much, but theres always the usual MAF sensor and Throttle position sensor faults that could crop up. Might be worthwhile get a diagnostic tester on it.....
Old Mar 16, 2006 | 05:58 PM
deankenny's Avatar
deankenny
diagnoster test, cool, where do i go for that, is it most garages or just some, and does it cost?
Old Mar 16, 2006 | 06:01 PM
SafeChav's Avatar
SafeChav
Hmmmm i dont know what dealerships would make of doing diagnostics on it if its not an original car, might be ok. I'd try and find some with a tester or try and borrow one or something. I can't be overly helpful on this as haven't had chance to play around with any diagnosable management systems yet
I'm sure someone else will spot this post who can give you some more advice
Old Mar 17, 2006 | 07:45 AM
frog's Avatar
frog
Sorry, can't help any further, I don't know that engine at all
anyone ?
Old Mar 20, 2006 | 08:27 AM
deankenny's Avatar
deankenny
dunno if this helps any1 understand what the problem is, but as im de accelerating the car backfires well not so much of a back fire but alot of popping than usual from the back
Old Mar 20, 2006 | 05:51 PM
Paul_RS's Avatar
Paul_RS
My RS turbo had a problem like this - juddered under light throttle but not when you booted it. Changing the spark plugs cured it for me.
Old Mar 21, 2006 | 12:10 AM
SafeChav's Avatar
SafeChav
I still think a diagnostics check
Rob Virgo
Oct 25, 2013 05:35 AM
xrsi
Dec 29, 2012 05:43 PM
Ben_r
Feb 8, 2012 06:20 AM
paceo
Dec 9, 2009 08:24 AM
paceo
Jul 27, 2009 09:10 AM
