megasquirt/injector help
Old Mar 8, 2006 | 11:17 PM
rauri's Avatar
rauri
up in smoke........
Default megasquirt/injector help
Ok i need some help,i have a zvh to go into my fezzy turbo and was going to just run the 195 superchip/bieges/fuel pump option but it was brought to my attention that this was a bit of a waste of my stage 3 head,t3 turbo,new cam so it was suggested i get aftermarket managment to get the best from it so it was decided to get megasquirt (coz im a bit poor) but i have no idea what injectors to use.i need some that will provide suitable fueling for 250 bhp (hopefully) and will be having the car set up by someone who knows what they are doing.
Does anyone have any suggestyions as to which injectors i cud use?
thanks,rauri
Old Mar 9, 2006 | 03:19 PM
tj_rs_turbo's Avatar
tj_rs_turbo
You can use yellow cossy on megasquirt. They are good for 270bhp. I am going to use that on my rst 1.6.
Old Mar 9, 2006 | 03:23 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
standard escos blule injectors should do the trick....theyre capable of about 270 ish bhp on a cossie..........but i'm not sure of weither they will fit in the zetec fuel rail or not...i think they should and it might be a cheaper option to use these as you can get them relatively cheap.
Hope this helps
Dan
Old Mar 9, 2006 | 04:08 PM
rauri's Avatar
rauri
up in smoke........
cheers guys
Old Mar 9, 2006 | 09:46 PM
rauri's Avatar
rauri
up in smoke........
anyone know the p/no's of the yellows/standard escos blues please?
Old Mar 10, 2006 | 11:12 AM
Garage19's Avatar
Garage19
Just buy a cheap second hand set off ebay (Ł20) and then have them cleaned and flow tested (Ł40).
Old Mar 10, 2006 | 11:33 AM
rauri's Avatar
rauri
up in smoke........
i was going to but i want to make sure i get the right ones,theres a few sets of yellow injectors and i dont know what the p/n (0 280 150 ***) is for the ones i want
Old Mar 10, 2006 | 11:43 AM
Garage19's Avatar
Garage19
That is a bosch part number. The yellows and blues that are stock in cossies are weber alpha parts so have a different part no.
these seem to be the best priced set with no parts missing on ebay at the moment.
http://cgi.ebay.co.uk/cosworth-rs-tu...QQcmdZViewItem
Old Mar 10, 2006 | 11:48 AM
rauri's Avatar
rauri
up in smoke........
ahh i see,i assumed they would be bosch p/ns,shud have realised they wouldnt be cbecause the standard fiesta ones arnt.thanks for your help m8
Old Mar 10, 2006 | 11:50 AM
Garage19's Avatar
Garage19
No probs mate. PM me if you get stuck with the MS project.
Old Mar 10, 2006 | 11:56 AM
rauri's Avatar
rauri
up in smoke........
ah yes the megasquirt,thanks for the offer....ive no doubt il be in touch
