Changing Escort Clocks
Old Mar 5, 2006 | 04:01 PM
Robby186's Avatar
Robby186
Default Changing Escort Clocks
I currently just have the bog standard speedo clocks in my escort, I want to change them for the GTi/Si clocks with the rev counter. Can I simply just swap them over?
My car: 1997 1.6 16v Escort Chicane.
Old Mar 6, 2006 | 10:51 AM
jonnyturbo's Avatar
jonnyturbo
it isnt simply a case of swapping the clocks over as the rev counter wont work. you will need all the connections for the rev counter from the donor car
Old Mar 6, 2006 | 03:40 PM
Robby186's Avatar
Robby186
Will the wires for the rev counter be on the loom in my car, so I can wire up the revcounter with the connection to the car?
Old Mar 6, 2006 | 04:19 PM
jonnyturbo's Avatar
jonnyturbo
doubt it mate
Old Nov 25, 2009 | 03:04 PM
maxwax's Avatar
maxwax
ive just got gti clocks and on my escort finesse there no rev counter ive been told that i will have to run a wire from ecu which is behind clocks find number 20 then run that to the blue plug that goes to back of clocks and put it in number 8 which they are numbered
Old Nov 25, 2009 | 05:17 PM
If the clocks are the same ignition type ie coilpack then all that's needed as said is a feed from one side of the coil, ie a negative, which is the outer wires on the coilpack, just see what colour they are and use one.
Getting the old connector from the car the clocks came from is always a good idea as you can see any differences then and copy them, on the older fords it was only a case of moving 1 wire and adding 1 more when going to tacho.
Vincereese
Jun 1, 2023 09:14 AM
FlashRS
Sep 14, 2015 12:36 PM
cameron2
Aug 25, 2015 07:18 AM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
