cosworth help needed please
Old Mar 2, 2006 | 05:07 PM
cossiegreg1's Avatar
cossiegreg1
Default cosworth help needed please
my cosworth has just been rebuilt and now when i fire it up it idles at 3000rpm. But if i remove the iscv it idles at 800rpm.I have changed iscv and it didnt change a thing.please help
Old Mar 2, 2006 | 05:38 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
vacum leal on inlet manifold
i had same with zetec turbo check all stubs are blocked of and all pipes are back on and going somewere
hope this helps
tommy
Old Mar 4, 2006 | 08:01 AM
cossiegreg1
but iv drove it and it drove ok,so surely if it is a vacuum leak then it wouldnt drive right would it???
Old Mar 4, 2006 | 02:07 PM
velocity's Avatar
velocity
it could be a vacuum leak.but if not. its possible that your throttle position sensor is not within adjustment where it is mounted on the throttle body
i had a similar problem after rebuiling my engine.
if you look at the sensor you will see that its held in position with 2 screws,the sensor has two slots which the screws go through.
as a ballpark the screws should be in the middle of the slots.if not loosen the screws and rotate the sensor by hand to get them in the middle or there abouts.even move it a little bit around the middle setting to see if it drops the idle to normal
if that doesnt work you will need a volt meter to get an exact reading with the throttle at a closed position,this reading is different depending if its a 2 wheel drive or 4 wheel drive sensor,
try the above and see how get on,if you need more info how to set up the sensor with a volt meter let me know
Old Mar 6, 2006 | 03:56 PM
cossiegreg1
cheers velocity i should hopefully be trying to sort it at weekend.
JoeyBoyden
Jan 4, 2024 02:36 PM
Aug 14, 2015 07:29 AM
col93saphcos
Aug 7, 2015 03:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
