how do u
Old Jul 25, 2004 | 02:31 PM
need4speed's Avatar
need4speed
Default how do u
how do you get a hub nut off on a sapp cossie 4x4, the nuts got a grove knocked into it which locks into the drive shaft ,also how do u stop the lot from turning when u turn the nut. cheers
Old Jul 25, 2004 | 02:52 PM
wimwerf's Avatar
wimwerf
put the car on the ground so the wheel can't turn. but the nut must come loose when you use a big tool. do you have tools which works on air or something?
Old Jul 25, 2004 | 05:05 PM
Dilly's Avatar
Dilly
or get someone to put there foot on the brake and use a big bar. it will come out of the groove
