Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
All about Marelli 2 and 3 bar MAP sensors
Old Jul 21, 2004 | 11:24 AM
foreigneRS's Avatar
foreigneRS
Testing the future
Default All about Marelli 2 and 3 bar MAP sensors
APS 02/03 - 05/01
Air pressure sensors, 2.0 /3.0 bar absolute
The APS xx series devices are high-accuracy and reliability analogue absolute pressure sensors.
Each pressure sensor exploits the piezo-resistive properties of silicon devices. The sensing element is a Wheatstone bridge located on a mechanically shaped silicon chip. A thick film hybrid circuit for signal amplifying is included in the same package. The same circuitry provides thermal compensation and noise reduction.
These active devices are housed in hermetically sealed plastic protective casings.
Technical data
Mechanical Characteristics
Dimensions (maximum) 77,5x65.0x41.0 mm
Nozzle diameter. 4.7 mm
Weight 88.0 g
Connector Mini-Timer 3 way
Performance Pressure range:
APS 02/03 17 to +216 kPa
APS 05/01 17 to +308 kPa
Operating temperature range -30 to +110°C
Response time less than 7 ms
Over pressure
02/03 200 %
05/01 450 kPa
Electrical Characteristics
Power supply 5.00 Vdc ±0.5
Output (min pressure) (at 5 Vdc supply) 0.25 V
Output (Full scale) (at 5 Vdc supply) 4.75 V
Protection Short circuit
APS05 Sensor output In mV (15.46 mV / kPa)
308 kPa = 4750 mV
162.5 kPa = 2500 mV
17 kPa = 250 mV
APS02 Sensor output In mV (22.61 mV / kPa)
216 kPa = 4750 mV
116.5 kPa = 2500 mV
17 kPa = 250 mV
Connector Pin Out
Important wiring note:
The connections A,B & C are identified as 1,2 & 3 on many commercially available minitimer connectors and may also be numerically reversed.
Looking towards the sensor so that the nipple is facing you, and the single mounting hole is at the top, the connector has 2 locating 'blocks' at the top,
(one at each end of the connector) and a single one in the middle at the bottom. Pin A (or 1) is on the Left, Pin B (2) in the centre, and Pin C (3) on the right.
PIN description
A + 5 Vdc
B GND
C Signal OUT
Also see:
https://passionford.com/forum/viewtopic.php?t=30245
Old Jul 21, 2004 | 11:28 AM
foreigneRS's Avatar
foreigneRS
Testing the future
For additional information,
1 kPa = 1,000 Pa
100,000 Pa = 1 bar
1 kPa = 0.01 Bar
Old Sep 13, 2004 | 03:12 PM
foreigneRS's Avatar
foreigneRS
Testing the future
for Bosch 5 bar sensors, the pin layout is as follows:
A GND
B + 5 Vdc
C Signal OUT
i.e. the ground and supply are swapped around compared to the Marelli MAP sensors.
Old Sep 2, 2015 | 08:43 PM
Tim Wharton's Avatar
Tim Wharton
Hi Nick
I know this is an old post but could you help me with a chart for a 3 bar sensor(APS05)
I've tried to calculate it my self from the (15.46mV/kPa) but it seams to be different depending on which end of the scale I try to calulate it from
-0.5 Bar----------Volts?
0.0Bar----------Volts?
+0.5Bar----------Volts?
+1.0Bar----------Volts?
+1.5Bar----------Volts?
+2.0Bar----------Volts?
Many thanks Tim
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
A.t.p
Sep 29, 2015 05:04 PM
jay030787
Sep 25, 2015 01:38 AM
