Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
Cosworth YB Manual - Section General
Old Jul 20, 2004 | 11:10 AM
foreigneRS's Avatar
foreigneRS
Testing the future
Default Cosworth YB Manual - Section General
General
The 16 valve Cosworth engine presents the key element of the Sierra RS Cosworth. It uses the engine block from the proven Ford OHC engine but is completed with a host of new components and systems
such as
• The new cylinder head with its two camshafts to actuate the 4 valves of each cylinder
• A water cooled Garret turbo charger
• A Weber electronic fuel injection system and
• an ignition system made by Marelli.
However, in addition to its unique power plant, Sierra RS Cosworth houses a host of other new or modi*fied components and systems a Service Technician needs to be familiar with and these are
• A close ratio 5 speed transmission
• New clutch and driveshaft
• Limited slip differential similar to Scorpio
• Revised rear axle mounting
Revised front and rear suspension with power steering and specially tuned shock absorbers and springs to meet Sierra RS Cosworths demands on road holding and road adhesion
• Teves ABS braking system similar to the system used on Scorpio.
In addition to this exciting list of features the interior has been redesigned to match the vehicles sporty appearance and to provide the driver with the environment required for a car of this class.
Oct 9, 2015 07:38 PM
Aug 14, 2015 07:29 AM
track.focus'd
Aug 12, 2015 05:53 PM
mick.slinn
Aug 10, 2015 01:38 PM
Old ford
Jul 31, 2015 06:50 AM
