Technical discussion: Exhaust manifolds on turbo cars
Re: Technical discussion: Exhaust manifolds on turbo cars
Importance and effects of: Length, size (diameter), rotational firing order etc.
Discuss .
Discuss .
I'd be saying the lower the backpressure the better. The turbo'll be creating backpressure as it is, so the shorter the exhaust and the bigger it's diameter the better, ie fat screamer pipe would be the ultimate. Am thoroughly prepared to accept that as poor theory if someone can prove it
Discuss .
Discuss .
Any resistance to flow is only ever going to lose you power IME.
you need an appropriate sized pipe (especially on an N/A car) to keep gas speeds up and hence help to scavenge the last fiew bits of exhaust gas from the chambers, but thats actually a negative back pressure at that point in the cycle (due to the vacuum created behing the gasses as they go up the pipe)
I cant picture in my mind ANY point in the cycle where having positive back pressure is actually a good thing?
Originally Posted by rsnissan
Originally Posted by J871yhk
unequal headers and funny firing orders sound better
but its true of rover V8s as well
Alex
Norris Motorsport
Mike this is one topic I wont discuss in public as it is the KEY to making power on a YB. The std 2wd manifold is shockingly bad compared to what a good tubular can produce. However as I don't make exhausts in general (only occasional one offs) I don't want to help any companies out who may read this site who do make them!!
Turbo cars please - or can't you read? So far, zip . I was expecting to here some discussions on what effect length and diameter has to gas speed etc . I suppose for an interesting discussion on this, I'll have to wait for Karl or Stu to post .
so is the only rover v8 I have worked on
Alex
Fair enough . I know how important it is and also how poorly designed the 2wd manifold is, so thought it might make a good topic for discussion.
Peeps, please don't confuse this with the exhaust AFTER the turbo, as it is irrellevant (apart from back pressure) on a turbo car. I am talking MANIFOLDS.
Sounds like you're going to need to make about five manifolds up using different diameters and primary lengths then Mike, and then dyno the engine with different manifolds to see what effects they have. Only surefire way to find out I suppose!
P.S. Then tell us of your findings
Testing the future
on a turbo car, i can't see a reason to specify a certain length, as i'd imagine that you can't 'pulse tune' the exhaust gas scavenging due to turbine back pressure.
i would've thought that lowering the back pressure as best as possible between the ports and the turbine is the priority , in which case bigger diameter is better, and as straight and short as possible, or at least gentle curves.
* NOT A FOR SALE POST *
Mike, why dont you get the ball rolling with your detailed findings and reasonings then?
That way Stu will have less to write when he comes along than if he has to start from scratch.
I dont have the depth of knowledge needed on the subject to feel i can contribute properly with an article on it im afriad, so its not laziness but a lack of experience that stops me posting an article on this one.
Intetesting topic though
Testing the future
does gas speed come into it?
is the work that the turbine can do a function of the gas speed through it, or the energy of the gas going through it?
the mass flow will be higher with a bigger diameter pipe as there is less pressure drop, but does that give more energy than a smaller mass flow with a higher speed that you would get with a smaller diameter?
Another clue as to why the design is as it is...
In fact, thinking about it, I'd say the shorter the primaries the better, because turbo's are more efficient when being bombarded by sharp "smacks" from individual exhaust pulses. A long primary builds in damping in the gases due to the volume, so the shorter the primaries, the more defined each pulse will be. That's more in relation to the way the turbo reacts to the exhaust gases though, as opposed to outright power production so, again, probably not the sort of discussion you're looking for here
Keep tine heat in is a good thing, as it means higher pressures, so from a perfomrance point of view i would say shorter = better.
But there are other factors such as shorter means more heat held close to the head so the potential for heat related failures increases (ie valves failing or head cracks)
Mike, you seem to have TOTALLY missed the point of these threads.
The idea is to give the information you have, not to regurgitate a couple of small bits you heard from someone else and try and sound mysterious and clever by not saying the rest when in fact its cuase you dont actually know the rest
Either speak frankly and in detail, or just dont bother to speak at all!
Chip,
I was just wondering how much knowledge there is out there about this side of things, and it seems very little.
I was just having an arguement with someone about the length and how this moves the power band around like a normally aspirated manifold does....
Chip,
is the 2wd manifold really that bad??
was always led to believe that as far as standar manifolds go the 2wd is one of the best
its practically a equal length tubular manifold...well almost
Testing the future
not convinced on the length, or the volume shifiting the power band
i could believe that by changing the length you are changing the pressure drop, as it may involve different radius bends.
It's still quite restrictive (above 550bhp) and isn't particularly efficient compared to a true tubular system.
karl sems to think a standard manfold that can be picked up for buttons and can run 500 bhp is "shockingly bad"
looks ok to me
Originally Posted by MADRod
Lets cut out all this Tec jargon With a 3" one car does 201 with a 3.5" one car does 210.
