Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
How I made my det cans......
Old Nov 21, 2005 | 11:53 AM
Garage19's Avatar
Garage19
Default How I made my det cans......
A few people have PMed me asking how I made my det cans, so I thought I would put all the info in a post with piccies.
What I used:
A good pair of ear defenders (no B&Q poo). Try a gun shop
Some copper pipe
A copper “T” piece
Some air line hose
Arraldite
What you do:
Drill a hole in the back of each ear muff (herr her, muff) and insert a short length of copper pipe. Make sure it protrudes past the insulation on the inside and has enough on the outside to jubilee your pipe to.
Arraldite the short sections of copper in, making sure they are fully sealed.
Use your air line hose to connect both ear muffs to the T.
From the T run a length of the hose under the bonnet.
Take another bit of copper pipe between six inches and a foot long. Squash one end (about an inch worth) flat in the vice and drill a hole though it. Make sure when you squash it that the end is totally sealed. Check it by blowing down it.
Bolt the squashed bit of the copper pipe some where on your engine block and jubilee the hose on the other end and you are done.
Basically it works like a doctors stethoscope…. But on a larger scale and for your engine.
In this picture you can see the hose coming out of the engine bay and into the car through the sunroof. We have used masking tap to secure it when mapping on the road.
One final note. When you use these kind of det cans you cannot map in the rain (apart from the sun roof being open)! The rain droplets make a real racket on the hose!
Doug.
Old Nov 21, 2005 | 11:57 AM
PMSL @ in the sunroof.
Why not just go through the door like this?
Or is it could you used such large diamter pipe you couldnt?
Old Nov 21, 2005 | 12:08 PM
ballin's Avatar
ballin
even if the tube was too thick you could at least crack the window and go in there?
little less vision obscuring!
Old Nov 21, 2005 | 12:20 PM
Garage19's Avatar
Garage19
The pipe was a big on the thick side but we tend to use what we can get our hands on for free out of the stores at work There was a nice big reel of airline hose!
Leccy window motor has gone kaput and it was too thick to go through the door seal so sunroof was the last option. Get some funny looks out on the road!
Old Nov 21, 2005 | 12:23 PM
rsnissan's Avatar
rsnissan
is that a boosted e30 m3?
Old Nov 21, 2005 | 12:28 PM
Garage19's Avatar
Garage19
Yup!
Old Nov 21, 2005 | 12:31 PM
Old Nov 21, 2005 | 12:33 PM
Garage19's Avatar
Garage19
Andy. See here.
https://passionford.com/forum/viewto...55536&start=40
Old Nov 21, 2005 | 12:39 PM
rsnissan's Avatar
rsnissan
quality job dude i love those E30 M3's at the best of times nevermind boosted
Old Nov 21, 2005 | 05:29 PM
boXXer's Avatar
boXXer
GASH!
what do people use them for? as in why does a normal road car (ie chips) have them? i thought only tuners used them?
Old Nov 21, 2005 | 05:50 PM
Billabong's Avatar
Billabong
I believe Chip maps his own car, hence his usage.
Old Nov 21, 2005 | 05:52 PM
boXXer's Avatar
boXXer
GASH!
ahhh, that would explain.
Old Nov 21, 2005 | 05:53 PM
Fiecos Dan's Avatar
Fiecos Dan
i put mine thro the balk head, or as chip does,
i use solid plastic air line, 6 or 8mm i think.
Old Dec 5, 2006 | 10:59 PM
escrst's Avatar
escrst
where bouts is the best place to position the other end to pick up detination?
Old Dec 9, 2006 | 04:55 PM
Fiecos Dan's Avatar
Fiecos Dan
i found best on a CVH and a cossie,
on the back of the block, if not on the centre inlet manifold to head stud.
Old Dec 26, 2007 | 11:38 AM
richard_syko's Avatar
richard_syko
As close to the head gasket as possible. Thats where the combustion chamber is.
Old Oct 8, 2008 | 11:45 PM
Smartdj.'s Avatar
Smartdj.
what sort of sound are you all listening for i want to start tuing my own car..these sound like a really good idea .."and cheap" plus i can get all the bits from work
Old Oct 9, 2008 | 06:05 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
Thing is, the type of hose, diameter and length affects the 'tuning' of it.. The ideal for det frequencies is 8mm fuel hose and about 6-7 ft in length.
Old Oct 9, 2008 | 08:22 AM
Smartdj.'s Avatar
Smartdj.
is the noise a kind of flickering noise
Old Dec 28, 2008 | 08:37 PM
jacko's Avatar
jacko
easy
Old Dec 28, 2008 | 08:43 PM
xr3iAlex's Avatar
xr3iAlex
XR3i ALEX
what is a det can ?
Old Dec 28, 2008 | 08:50 PM
Garage19's Avatar
Garage19
A device for hearing detonation in an engine for tuning purposes.
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
Alloy wheels and ICE for sale
Sep 28, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
focuspower
Sep 20, 2015 03:51 AM
