Taking a RST gearbox apart (Pictures)(Finished)
#46
While you've got the camera out, can you take a pic of the end of the mainshaft (the bit that runs in the open roller bearing)
Nice clear close-up will help
#50
Ex Ford Man
which one is the mainshaft ? the one with the most gears ?
#54
#57
yup sure he ment that other end.
just make sure that it doesn't look like this:
http://photo.jippii.fi/fi/image//dat...456829070.jpeg
#66
Ex Ford Man
LOL
None, yet as i'm waiting to get this gearbox done. Once thats outta the way, i can start to make the mould of the dash i want, also try making some pannels first.
Sent the 2 diffs off today to get the bearings swapped, if they can, if not, there gonna fit a new one.
#69
Adam, have you got access to a vernier caliper?
Your mainshaft has a bearing sleeve fitted, which is a good thing, just so long as the mainshaft hasn't been turned down to fit a small bearing.
If it has, it will snap....
Measure the diameter of the shaft (the bit sticking out of the bearing will do).
If it is 25mm, then it's time to worry I'm afraid.
However, if it is 27.5mm, carry on - you're doing fine
#71
Good work Adam - no sustitute for getting in there and doing it yourself if you want to learn anything... Far too many people want to rush off and let someone else do it - don't learn anything that way.
No offence to Bernie here - there's some top advice coming from him, bearing in mind he doesn't have to.. I'm sure he's got more than enough to do to worry about a couple of DIYer's taking away his business
Good thread this one!
#72
PassionFords Creator
richm,
Im interested in this too as i know SFA about transmissions.
#73
Originally Posted by Stu @ M Developments
100% Agree.. its peeps like Bernie that make PF what it is
#74
Im no more likely to do that, than Bernie is to start fooking about trying to map his car....
Much as god loves a tryer.. when i put my foot down 300miles from home i wanna be confident that an expert did the engine, and an expert also did the transmission.
No offence to everyone who likes a biy of DIY.. but in my experience, most DIY jobs will simply be a case of fixing what was obviously wrong.. Its experience that spots things like the shaft not being 27.5mm and being a disaster waiting to happen whilst your in there...
And we all know that only a short time will elapse betwen us refitting our DIY part and that disaster getting bored of waiting.....
#75
LOL, true words Stu...
But - I'll wager you didn't know much about mapping, and Bernie didn't know much about gearboxes when you were in your prams... I'd fancy that you started doing a bit of tinkering.. ?
#77
Ex Ford Man
So what does that mean........do i need to upgrade ?
#79
Thanks for the kind words peeps
Adam, give me the number stamped in the crownwheel, and I'll see what i can do
If you weren't so far away, I might have been offering you a job!
