Technical essay Archives A collection of topics you really shouldnt have missed first time round if your interested in the technical aspect of how these Fords work..!! Also many Workshop manuals available in downloadable format. Access is available to Gold Members only.
compression
Old Mar 30, 2008 | 11:28 AM
spanner-86's Avatar
spanner-86
Default compression
with the technology and progression tuners are applying to the YB engine the cylinder comperssions are varying vastly, i am asking for a vote, on a turbo YB what is better higher than standard (8.0:1) or lower than standard compression ?
Old Mar 30, 2008 | 07:30 PM
cosrep's Avatar
cosrep
I'm currently looking into running higher than standard compression for my new YB engine build so at the moment higher gets my vote. I recently rebuilt a RB25DET (skyline engine) to run big boost and low compression - low compression on one of these engines is 8.0:1
Old Mar 30, 2008 | 07:44 PM
Mark Shead's Avatar
Mark Shead
I say 8-1 is no problems up to 600hp and maybe above it, The next 700hp engine I will be biulding will be around 7.9-1,
But the question will not have the same answer between other tuners as it wont be as clear cut as it appears,
There are many other things you need to look at also, It is not as easy as a car turning up at 8-1 and saying give this engine 600hp as you realy need to biuld from a known spec to make the higher comp engines work and be reliable.
Mark
Old Apr 10, 2008 | 01:51 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Mark,
If an engine was mainly used on track would you still be happy building an engine that is above 7.5:1?
Old May 9, 2008 | 06:01 PM
glancy2081's Avatar
glancy2081
have you built the above engine mark if so what was the results
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
