944 Project begins
Old 18-06-2017, 08:28 PM
Thanks for the pictures, should be easy to find a bell housing. I did have one from an early 924 I think it was that people used to put the 2.2 5 cylinder audi's in but no idea where thats gone in the garage
Old 24-06-2017, 11:41 AM
Old 24-06-2017, 11:46 AM
Re the pics above, I have started making the template for the 2nd part of the adapter, I had to find a normal level datum so used a spirit level on the mounts for the clutch slave as that sits level in the original car; this should make the engine sit at correct slant.
I sprayed around the bellhousing to get a rough shape, I will make the prototype template in 2 bits of 10mm ally to see how the spigot looks in the flywheel to ensure it doesn't go in too deep.
The wings on the first plate locate the oe bolt holes on the mk4 golf bellhousing, there will be 5 bolts in total and these will stop the 2 part adapter twisting, I will use all but 2 of the original oe bellhousing bolt holes and before making a run of adapters I will make sure the adapters trim down and look neater.
Old 24-06-2017, 11:48 AM
The wife has gone horse riding so I have put the dirty bellhousing in the automatic parts washer (dishwasher) to clean it up before painting it.
Old 24-06-2017, 01:45 PM
lol, hope she's gone for a while before the cycle ends
Good progress, I had seen a couple of other ways for this being done, one was a guy in america used a s4/rs4/s2 aby spacer plate welded to a early 924 bell housing instead.
Caddyshack (24-06-2017)
Old 24-06-2017, 07:06 PM
I see a 944 on Thursday and thought of your project. Keep the photos coming.
Old 24-06-2017, 07:28 PM
She caught me but didn't seem too fussed. Must be getting used to it. Might try bringing home a 23 yr old from the pub next!
Old 24-06-2017, 07:52 PM
mk1turboestate
mk1turboestate's Avatar
How well does the dishwasher work, ours is only about a year old but it's getting changed with a new kitchen so was thinking of putting it in the garage for just such an occasion
Old 24-06-2017, 08:20 PM
Actually works really well, I have a Clarke parts washer but the dishwasher does it much better, I have put remote control car chassis parts in too.
mk1turboestate (24-06-2017)
Old 24-06-2017, 08:54 PM
Old 25-06-2017, 07:41 AM
sridgett
The only way is dagenham
sridgett's Avatar
I love these cars, my dad has one. A s1 not a turbo. Looking forward to updates
Old 25-06-2017, 10:25 AM
Toby you have just made my day that's so funny seeing that bell housing in the dishwasher pmsl
Caddyshack (25-06-2017)
Old 15-07-2017, 05:31 PM
The adapter plates are now made in prototype, need to fit up to donor engine now and check tolerances for clutch and flywheel, will then off for a few laser cut finals. Looking forward to getting it running and then tuning to see what power I can get for reasonable money 300 bhp first target and then see how that feels before looking for more.
Old 15-07-2017, 07:55 PM
glad to see your still progressing with this, let me know how you get on with the adapter plates i'm still interested in the conversion bits.
Old 16-07-2017, 12:40 PM
Don't worry, I haven't forgotten you. I plan to do a basic set of instructions and have simple arrows etched on the plates to show which was points to the back of the car and which way is up.
Old 16-07-2017, 06:11 PM
Thanks, whats next for the car?
and 300bhp should be quite easy to get on stock internals, probably the downpipe fabrication would be the hardest part. A cheap ebay log style manifold should work for this setup going by my mates 1.8t in his audi coupe gt, there was still loads of room compared to the stock manifold
Old 16-07-2017, 06:16 PM
Yeah 300 doesn't seem too hard on these engines.
I need to mock up the engine in the car and then fabricate some engine mounts, I may get my friend to make them with an eye to sell a few but if not I will just make some basic ones myself.
Once the engine is in and running I plan to do an inexpensive suspension upgrade and I have some big Porsche calipers from an old project so just need to add some bigger discs. I really don't plan to go mad, probably just make it light and a half decent cheap cage.
Old 29-10-2017, 06:43 PM
any progress or you been out running around in it going by previous projects progress
Old 30-10-2017, 04:08 PM
I have had a bit of a break from the garage recently but last weekend I put the 944 up on my ramps ready to offer up the gearbox this weekend coming so I can trial fit the engine to the adapter and make some engine mounts.
PaulinhoT (30-10-2017)
Old 31-10-2017, 03:10 AM
cool, just checking
Old 04-11-2017, 05:38 PM
Got back out in the garage and had a good day on the car, really enjoyed it.
I mounted the new 5 speed manual and torque tube, gear selector and cross brace ready to rebuild the rear suspension. For now I will just for decent Shox at the rear and put thicker torsion bars later or do coilover conversion.
I have also started making the engine mounts and they locate on the original 944 mounts on the front cross member. I should be able to offer up the engine next week and then start things like the exhaust etc.
One of my old VW mates is going to adapt the 1.8t loom to plug straight in to the porker fuse box running standard ecu and then I will get it mapped once the bigger turbo is on.
Old 05-11-2017, 08:04 PM
have you thought about getting adapter looms to sit inbetween both looms and make it easy to do the conversion made?
Glad to hear your still enjoying working on it.
Old 05-11-2017, 08:11 PM
It seems some have Vw fuse boxes that would make it easy. My engine just needs an Earth and positive to run as it is so complete but will see what can be done.
Old 06-11-2017, 12:12 AM
Thats interesting to know
Old 06-11-2017, 07:18 PM
stu20004x4
mk6 escort fantasist
stu20004x4's Avatar
great build thread, will be watching with interest as i plan on tracking my new buy
Old 06-11-2017, 07:22 PM
Nice 924. Will you keep the standard engine? I bet the 924 can be pretty quick as it is very light. Lots in common with mk1 golf as it was to be the scirocco mk2 paid for by Vw and built by Porsche. VW pulled the plug and Porsche carried on with the project, I can see lots on the 944 in common with the Vw parts (and a few Vw part numbers)
stu20004x4 (07-11-2017)
Old 06-11-2017, 08:43 PM
300+
Good work chap ..keep it up .
Old 07-11-2017, 04:37 PM
stu20004x4
stu20004x4's Avatar
at the moment i want to keep it standard, but been told its not the fastest. not sure what my conversion options are yet, anny suggestions welcome lol. My cossie is draining me enough so cheaper the conversion on the 924, the better. I have been keeping an eye out for a crash damaged boxter though lol.
Interesting story on the VW/Porsche deal, never knew that
Old 07-11-2017, 06:40 PM
Not sure what bits a boxster will help with other than brakes.
The 1.8t 20v engine fit quite easily so you have 150bhp,to 225 bhp standard and easily 250 plus then 350 and up if you want to get stuck in. If it is nice to drive and super original it will be worth more standard to some but is never going to be a fast track car without work....they handle very well though.
Old 11-11-2017, 11:39 AM
Today I fixed the one bit of rust that I found on the car, it was near a suspension point so would have been an MOT fail, I cut out all the rot (about the size of a fag packet) and welded in new metal and then sealed and painted it. I have now ordered the powerflex bushes and solid mounts for the rear suspension and I can then fit all the rear up.
Old 11-11-2017, 06:52 PM
I’m in the workshop on Wednesday Toby I’ll see what drawings I can find
Old 11-11-2017, 07:10 PM
Cool, would like to put some good suspension on it.
Old 12-11-2017, 09:17 PM
Minirotty
Lucifer II - 666
Minirotty's Avatar
Great project! I love 924's and 944's and drooled over loads yesterday at the NEC classic car show, was over them like a rash lol be following this one.
Old 13-11-2017, 09:36 AM
Was the NEC good? I had thought of going.
The 924 and 944 was the unloved Porsche but leave the EGO aside and they are brilliant cars, I really like driving them.
Old 13-11-2017, 04:41 PM
Minirotty
Lucifer II - 666
Minirotty's Avatar
Was a good show, but not well laid out, porelynorganised imo asnone hall looked like another... so much of the same cars in each hall.
Unloved I get! The NEC show had EVERY marque of Jaguar there, but not one XJ40! Couldn’t get my breath at that.
Heres some Porsche’s I saw and liked.
This one is my dream supercar, I love it that much, I painted one of my brick Porsche GT3’s actual Porsche Mexico Blue!!!
Old 13-11-2017, 07:02 PM
Thanks for posting, I like all of those. Always liked the 924 GTS.
Old 19-11-2017, 10:43 AM
It is nearly back on its wheels, just ordering up some service parts like handbrake shoes and new brake lines. I have found that quite a lot of the Porsche Range fits, I.e. With a little adapter you can fit 993 brakes right up to turbo big reds. The car will be light so might just try ebc ultimate pads and discs all round and see how I get on, these are cheap for a full set.
I will pick up the engine very soon and offer it up and finish the engine mounts.
Old 20-11-2017, 01:33 AM
I have not been overly interested in the 924's, there was a black turbo nearby for ages but I think it was going to be rotten as its been parked for a long time before I next saw it up for sale on a site.
I've got my eye on a black 944 auto currently, interior is screwed which I don't care about as its tan. The body doesn't look too bad. I'm just waiting to see how a situation plays out at work before going for that as my money might be needed elsewhere. My last project has been sold on and the spares are up for sale so it all just depends on work and my wife. The boss said I can store it at work so that would be no problem.
Spent a while on tipec the other night to get an idea of what I want, and think the 1.8t is the way to go.
Old 20-11-2017, 05:40 PM
Good man, get it bought. The swap to manual is a doddle to do, it is just a few bolts although I haven't done the pedal box yet but it will be bolt in I am sure.
Old 21-11-2017, 01:36 AM
Yeah i'm sure the pedal box will be an easy task. If at worst the clutch pedal can probably just be added providing the brake pedal isn't a huge us spec lump.
I will be seeing how the next couple of weeks play out. Hopefully
