Cossie and other ford parts clearance! updated 5/6
Old May 14, 2012 | 10:20 PM
Turbo Zetec's Avatar
Turbo Zetec
Engine Machinist
Default Cossie and other ford parts clearance! updated 5/6
right, starting this tonight, but will add more every day as i clear out my garage!
Cossie bits:
cossie scrap head, not worth rescuing ever. ideal ornament or on a mock engine £20
crank sensor and mounting bracket £15
standard cossie 'KA' pulleys £5 each SOLD
4 Cossie 4wd pistons, std size £30
2wd alternator bracket £10
2wd PAS bracket £10
4wd header tank, some cracks as usual £10 SOLD
front main oil seal housing, £20
2x front dizzy shaft oil seal housing £10 each
koni rear shocks, need rebuild £15 the pair
dizzy shaft £10
kidney box £10 SOLD
coil £5
cambelt tensioners £10 each
cambelt tensioner nut £5
sapphire cossie bumper brackers, brand new! £offers SOLD!
3 bar map sensor, broken but repaired, ideal as spare £20
4wd clutch arm and pivot £20
4wd release bearing £10
water pipe from pump to matrix (i believe its from a 2wd) £5 SOLD
2wd gear lever, will be welded together and stronger than standard £20
throttle cable bracket £5
crank pulley bolt £5
dizzy shaft £10
group a coil £15 SOLD
breather thingy as pictured £5 SOLD
2 Cossie 4wd Front calipers, £50
4wd gearbox, less the front casing (it was used on a 2wd mt75) £80
sapphire cosworth side skirt rear halves only. £5 each
other ford bits:
(soon for sale) Zetec turbo blacktop block with vauxhall pistons and balanced st170 crank, was going to use this in my car, but have had a change of direction. has a spigot bearing in for RWD application if needed. not yet run. £400
(soon for sale) Zetec head with 1mm oversize inlet and 3mm oversize exhaust valves. 3 angle seats. ported and polished by the same place that did speckys tigra head up until last year £400
(soon for sale) Ported CVH EFi head, bronze guide sleeves, 3 angle seats, stainless valves, double springs, done by same place £250
Adjustable TCA's for mk4 escort, one slightly bent, but probably repairable. £15
Mfi xr3i Pipercross air filter, £10
efi k&n (not sure its the official one, but was fitted to an efi '3i), £10
'D' shape steering wheel, £15
Orion RS overbumper! rear only, a bit of a mess, but someone could rescue it! rare these days £20
2wd rear ARB £10
Snap on impact gun, £60
sideskirt clips, brand new. 3 short, 1 medium and 8 long available. £5.00 each
Old May 16, 2012 | 11:53 PM
Turbo Zetec
Engine Machinist
lots more added 17/4
Old May 17, 2012 | 12:30 AM
Turbo Zetec
Engine Machinist
17/5 even, i seem to have lost a month!
Old May 17, 2012 | 07:03 AM
COCHYN's Avatar
COCHYN
Send a PM to Graham C about the pistons, I know he was after a set but not sure on which size
Old May 17, 2012 | 09:45 AM
s2builder's Avatar
s2builder
would it be possible to ship some small parts to Belgium?
Old May 17, 2012 | 09:55 AM
s2builder's Avatar
s2builder
if possible, i am interested in;
kidney box £10
auxiliary shaft pulley, (only the pulley)
Cheers, Andy.
Old May 17, 2012 | 09:57 AM
Rob Virgo's Avatar
Rob Virgo
Water pipe,header tank and gpa coil please , postage to cork,Ireland....
Old May 17, 2012 | 09:58 AM
SS1's Avatar
SS1
pics please sapphire cossie bumper brackets,
First call if selling do you Have PICS of the above
Old May 17, 2012 | 10:00 AM
stucapri2.9iTT's Avatar
stucapri2.9iTT
pm sent
Old May 17, 2012 | 01:28 PM
Rob Virgo's Avatar
Rob Virgo
S2 builder
Better to start a new post instead of editing as it appears you were ahead of me for water pipe whereas I asked for it first....
Rob Virgo's Avatar
Rob Virgo
Sorry, I meant a new reply
Old May 17, 2012 | 02:15 PM
s2builder's Avatar
s2builder
oh, ok sorry Rob, you where first indeed! cheers
Old May 17, 2012 | 11:16 PM
Turbo Zetec
Engine Machinist
kidney box £10
Cheers, Andy.
will find out the postage and let you know asap!
same as above, will hopefully get them to the post office to price up tomorrow or first thing Saturday
they are pictured above sitting on the end of the konis. let me know if you'd like a clearer picture though. i am selling them, just not sure what they're worth! make me a sensible offer
Originally Posted by stucapri2.9iTT
pm sent
replied
Old May 18, 2012 | 08:40 AM
s2builder's Avatar
s2builder
ok! thanks!!! cheers, Andy
Old May 18, 2012 | 12:54 PM
DAN-Saff's Avatar
DAN-Saff
They look like Esc cos bumper brackets not Saff ones as they are a big kinda rectangle ish shape
Old May 19, 2012 | 09:25 AM
Turbo Zetec
Engine Machinist
they look similar to the ones on my sapphire bumper, plus they have an 87 part number, so I think they're sapphire ones.
Old May 19, 2012 | 12:22 PM
AndyR1's Avatar
AndyR1
hello payment sent for sapphire cossie bumper brackets cheers andy
Old May 19, 2012 | 03:04 PM
turbo m's Avatar
turbo m
Would you sell the spigot bearing for the rwd application. and how much?????
Old Jun 5, 2012 | 05:31 PM
Turbo Zetec
Engine Machinist
updated and more added!
Old Jun 5, 2012 | 05:32 PM
Turbo Zetec
Engine Machinist
afraid not, you can still buy these mega cheap new anyway.
Old Jun 5, 2012 | 06:15 PM
Rozvor's Avatar
Rozvor
Are fine? Total amount with shipping costs to Spain?
Old Jun 5, 2012 | 06:43 PM
joe s's Avatar
joe s
How much for the RS Orion accessory apron posted to RH15 mate??
Old Jun 5, 2012 | 08:23 PM
RSDog's Avatar
RSDog
Have you got a good petrol tank? If so how much posted?
Old Jun 5, 2012 | 10:33 PM
jamie's's Avatar
jamie's
how much is the postage on the pistons?
Old Jun 5, 2012 | 10:55 PM
2ndGear's Avatar
2ndGear
its a v6 gearbox that mate, got the long input shaft
Old Jun 8, 2012 | 05:27 PM
cossie891's Avatar
cossie891
I have sent you a pm mate
Old Jun 8, 2012 | 07:12 PM
Turbo Zetec
Engine Machinist
are fine as far as i know, will have a measure before i take payment for them though will get you a postage price tomorrow
i really have no idea its bloody huge! not really sure how i'd package it either without it getting damaged on its way any ideas?
afraid not sorry
gotta offer them to rozvor first, but will let you know if that falls through
correct! nothing a hacksaw wouldn't sort though
replied
Aug 14, 2015 11:21 AM
Botts
Aug 13, 2015 04:16 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
