4x4 Saph Cosworth Parts and Uprated Parts *Updated 30.4.12* PIC HEAVY!
Old Nov 5, 2011 | 10:52 PM
joe s's Avatar
joe s
Default 4x4 Saph Cosworth Parts and Uprated Parts *Updated 30.4.12* PIC HEAVY!
This is just some of the bits I have left from breaking both my Saph's. I do have boxes of other bits so just ask and I'll do my best to find the bits.
- Valve Stem Seals Inlet & Exhaust BNIB - £30
- Turbo gasket Rebuild Kit BNIB - £25
- Escort Cosworth Cam Cover with Piller Mounts used - £35
- Turbo Heat Shield. Been chewed by the look of it - £20
- Pair of Actuators. One with rod is slightly bent. Not sure if one is -31. - £40 pair
- Injector Loom. Good for plugs or repairs to another loom - £40
- Plenum Spacer - £25
- 2wd Inlet Plenum - £30
- 1x Vibra Technics Engine Mount (used) - £30
- 1x Normal Engine or Gearbox Mount (not sure which) - £10
- Wasted Spark Coil Pack - £20
- Chrome Header Tank (not sure of make) - £50 (Sold Pending Payment)
- In car boost adjuster and hoses. Unsure of use - £25
- Red Samco Boost Hoses - £60
- Stut Brace, been sprayed Black at some point with the mounts silver. Small dent on underside - £45
- Momo Millenium Steering Wheel (couple of marks) - £60
- Fuel Filter Brand New Never Used - £12
- 4x 17" Kahn 5 Spokes in need of refurb with Kuhmo tyres (one kept going down) - £100
- Pair of Driveshafts (poss Fr) in need of refurb - £35
- Front Prop - £20
- Alternator with Multi Rib Pulley - £35
- Washer Bottle - £10
- Front Diff (unsure of use) - £65
- Rear Diff (unsure of use) - £45
- Gearbox Cradle used - £10
- Rear Diff Mount in need of refurb - £5
- Front Braided Brake Lines (unsure of make but new) - £25
- Red PF01 TPS - £35
- Grey PF01 TPS - £35
- Grey PF09 TPS - Sold
- Multi Ribbed Belt (New Bought in error) - £10
- Pipercross Cone with Trumpet - £35
- Denso Iridium Hi-Power Spark Plugs (New unopened) - £40
- 4x4 Remote Oil Cooler Arm Long Nut - £5
- 4x4 Remote Oil Cooler Arm - £20
- 2wd Oil Pick up. Unsure of use - £15
- Wolfrace Locking Wheel Nut Kit (Unopened) - £40
- 4x 205/40 17 Yokohama Prada 2 BRAND NEW, NEVER FITTED - £250
- 2x Delocked Front Doors (No Mouldings attached) - £40
- 2x Rear Doors (No Mouldings attached) - £30
- Bailey Swirl pot - £50
- Bottom Rad Pipe, Been Black Enameled at some point - £10
- Group A Coil (Used) - £30
- Pas Pump - £20
- 4wd Thermostat Housing (Powder coated Silver) used - £30
- 2wd Thermostat Housing used - £20
- Unknown Thermostat Housing - £10
- Dump Valve Blank Plug - £10
- Clutch Fork - £10
- Dizzy with Dizzy Plate used - £15
- 4x Jacking Point Covers in White (could do with tlc) - £60
- Crank Bolt and Washer used - £5
- Flywheel Bolts x9 & Other Bolts Pictured - £10
Pictures can also be viewed at http://photobucket.com/joes_cosworth. I will be updating it as much as I can.
Lots of Interior trim, clocks and Late Spec Dash parts also in my loft from the last one I broke.
All items are plus p+p or collection from West Sussex. I can take things to the local meet (if I can get there).
I have tried to be as honest as I can as I don't like being messed around myself. All items are used unless otherwise stated. There are more in boxes that I have been collecting over the last 3 years to build my car so I will try and get everything out and photographed asap but like I said work is mental and time is short. If you are local then you are more than welcome to come and have a look for yourselves, the kettle is always on in my house
If anyone has any suggestions about prices then please let me know.
Joe
Old Nov 8, 2011 | 02:44 PM
joe s's Avatar
joe s
Updated
Old Nov 8, 2011 | 05:01 PM
robby421's Avatar
robby421
interested in few bits mate pm me contact number an we will sort a deal out cheers
Old Nov 8, 2011 | 06:38 PM
P4ULT's Avatar
P4ULT
how much for the intercooler posted please
Old Nov 8, 2011 | 08:29 PM
Dicko&Vacant's Avatar
Dicko&Vacant
044 pump arrived today Joe thanks for the excellent service.
Old Nov 8, 2011 | 08:46 PM
joe s's Avatar
joe s
Will sort that out for you once my Pm's are sending again, having a little trouble at the moment.
Old Nov 8, 2011 | 08:47 PM
joe s's Avatar
joe s
£135 Posted ? ?
Old Nov 8, 2011 | 08:48 PM
joe s's Avatar
joe s
No problem mate, hope it does the job
Old Nov 8, 2011 | 09:09 PM
robby421's Avatar
robby421
i after intercooler radiator 4x4 exhaust manifold how much posted? as you cant send e number cheers
Old Nov 8, 2011 | 09:12 PM
joe s's Avatar
joe s
I cant see them being anymore than £20 posted if wrapped carefully as one package. £245 posted?
I dont have a 4x4 manifold mate, only a 2wd mounted on the engine.
Old Nov 8, 2011 | 09:51 PM
robby421's Avatar
robby421
ok would pay pal be ok? an where abouts are you in west sussex? an depending where you are i could collect
Old Nov 9, 2011 | 12:37 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Alright Joe,
Sorry to see you're breaking mate but needs must eh?
How much do want for the foglight surround trims?
Gaz.
Old Nov 9, 2011 | 05:55 AM
joe s's Avatar
joe s
Paypal is fine mate or bank transfer. I'm in Burgess Hill, about 15 miles from Brighton.
Old Nov 9, 2011 | 05:57 AM
joe s's Avatar
joe s
Originally Posted by Kitchen Devil
Alright Joe,
Gaz.
Hi Gaz,
Long time no speak! How's your car going? Still have the ST24??
Ideally I want to sell the shell complete as it took forever to shift the last one and I really dont want to be lumbered with a shell. If it looks as though I have to break it then I give you a shout mate
Old Nov 9, 2011 | 08:08 AM
robby421's Avatar
robby421
you have pm mate
Old Nov 10, 2011 | 06:49 AM
joe s's Avatar
joe s
you have pm mate
Replied and sorted mate
Old Nov 10, 2011 | 08:30 AM
Gazzonator's Avatar
Gazzonator
Gary Krishna
Hi Gaz,
Alright mate!
Cossies still in pieces, should hopefully be be back up and running for February!
The ST went a little while ago, bought a Mondeo V6 Ghia X but that needs a couple of bits doing to it to get it back on the road. Running about in a 1400 Astra estate at the mo and I hate the bag of shit with a passion!!
You still got the ST TDCi?
Old Nov 10, 2011 | 08:34 AM
joe s's Avatar
joe s
Alright mate!
All cossies are pieces !! I still have the ST but may get rid next year as had it four years now. I have a Renault Laguna Estate that I bang around in for tip runs etc.. Gave 100 quid for it off one of my customers as she was going to scrap it. Good car!!
Old Nov 12, 2011 | 05:38 PM
joe s's Avatar
joe s
Updated
Old Nov 13, 2011 | 12:08 PM
joe s's Avatar
joe s
All sold items deleted
Old Nov 13, 2011 | 08:02 PM
kaisersolsay's Avatar
kaisersolsay
Got the clutch....top man cheers
Old Nov 13, 2011 | 08:22 PM
joe s's Avatar
joe s
Nice one, I hope it does the trick
Old Nov 13, 2011 | 08:51 PM
robby421's Avatar
robby421
i collected rad an cooler toady nice fella an very pleased with rad an cooler cheers mate!
Old Nov 14, 2011 | 05:54 AM
joe s's Avatar
joe s
Glad you are happy with them mate. Nice to have met you and the missus. I'll let you know about the other bits
Old Nov 14, 2011 | 06:33 AM
anglia105e hinson's Avatar
anglia105e hinson
Alright mate I'm after all the air con stuff pipes, pump, bracket on the engine and wiring if you can get it. Cheers
Old Nov 14, 2011 | 06:34 AM
joe s's Avatar
joe s
Hi mate,
I'm trying to sell the shell as complete as possible but if I have to break I'll let you know.
Joe
Old Nov 14, 2011 | 06:45 AM
anglia105e hinson
No worries cheers mate
Old Nov 14, 2011 | 09:47 AM
R4N SS's Avatar
R4N SS
do you have the 4x4 gear surround - the plastic that goes around the gear stick?
Old Nov 14, 2011 | 12:16 PM
joe s's Avatar
joe s
I have a mint one with no split mate but I wanted to sell the shell complete. If I have to break it I'll let you know.
Joe
Old Nov 14, 2011 | 12:53 PM
R4N SS's Avatar
R4N SS
Joe
No probs mate - i only wanted it as a spare anyway
Old Nov 14, 2011 | 06:01 PM
joe s's Avatar
joe s
Updated
Old Nov 16, 2011 | 05:02 PM
joe s's Avatar
joe s
Updated list and pictures in the album
Old Nov 17, 2011 | 06:05 PM
carls9941's Avatar
carls9941
u have pm
Old Nov 17, 2011 | 06:50 PM
1stcoz's Avatar
1stcoz
Hi do you have a pic of the Ally Fuel Pump and Filter Cradle.
Thanks John
Old Nov 17, 2011 | 06:53 PM
1stcoz's Avatar
1stcoz
Thanks John
Sorry mate just found the link.
Old Nov 17, 2011 | 07:33 PM
P4ULT's Avatar
P4ULT
Old Nov 22, 2011 | 06:06 AM
joe s's Avatar
joe s
Updated
Old Nov 23, 2011 | 07:30 AM
Rsmat's Avatar
Rsmat
Do you have a pf09 4x4 tps.. Mate ?
Old Nov 23, 2011 | 01:34 PM
joe s's Avatar
joe s
I'll have a look mate
Old Nov 27, 2011 | 10:32 AM
joe s's Avatar
joe s
Bump
