cosworth parts new bits added
3 door mint ford engine loom removed from low mileage 3 door £130
BIG REAR BRAKE CONVERSION BRACKETS AND BELLS ONLY £100 COMES WITH DISCS IF WANTED BUT THEY ARE SCRAP
2wd lower arms pair new £40
ford racing fuel and water gauges £25 each some bits missing
esc cos fans £60
escos front callipers /pads discs £80 callipers good ,pads and discs usable offers
all plus postage
more will be listed as i remember
contact jeff on 07830723912
esc cos fans £60
all plus postage
you have PM. about AP bells i will have them if they are ok. asked about price but then saw the price in the thread. sorry.
2wd diff and hanger ,,good condition £200
group a coil as new £20
4x4 front diff £50 73k
4x4 rear diff £90 73k
4x4 full propshaft both parts /and doughnut bush £80 73k
4x4 sump £25
4x4 crossmember £25
4x4 gearbox /engine spacer ,dirt sheild £15
chrome throttle holder bracket £20
esc cos hockey sticks been repaired genuine ford nice condition £50 pair
esc cos lower genuine ford spolier need paint to make mint £60
2 x escort cos front hubs one has flange missing other had drive shaft stuck inside £ 60 for the pair ...no abs sensors
4x4 saff dash mint condition and handbrake console £50 MUST COLLECT steering coloum surround and some other bits
saff 2wd fans £30
esc cos fans £60
all plus postage
4x4 sump £25
4x4 crossmember £25
saff 2wd fans £30
esc cos fans £60
all plus postage
hi mate do you have a 4x4 gearbox crossmember and also one of the bolts that holds it too the floor (the flat piece of metal with two threaded studs that goues into the groove in floorpan either side of box) if so how much delivered mate?
tight arse
