Forged ZVH, NOS Kit & other cheap parts!
1.8 ZVH complete with H section rods & accralite pistons, compression ratio of 7.8:1. Has correct sump for RST and comes with modified engine mount and steel, lightened and balanced flywheel. The correct non-stretch head bolts are included too.
Everything to bolt in basically.
Engine ran consistant 105mph terminals at santapod and never used any oil. Hone marks still present on the bores too. Would make someone a nice reliable fast engine with a decent cylinderhead and camshaft added.
£400 collection only.
Magnecor 8.5mm HT leads. £25 delivered.
Series one ECU's Fuel & Ignition - Unkown chip but run well on my car with no problems. £45 delivered.
RST metering unit in good working order. £40 delivered
Nearly new S2 alternator £25 delivered.
Wizards of NOS Street blaster kit complete with 5 lb bottle (1/2 full), pulsoids, crossfire injector, TPS switch & micro switch, pressure gauge and associated connectors & switches. Will need some nylon piping as its been cut to suit an RST installation. Nylon piping is cheap and easily available. £300 (This kit cost over £600 and has been used twice.)
Good condition fuel injection petrol tank, pattern part. £40 Collection only.
Thanks for reading
Gary
Thanks for reading
Gary
Ive had no problem with the cam and the engine was very quiet before being pulled apart and run a 14.0 @ 104 on the last time it was driven which was central day @ the pod.
The radiator hoses are above in the post with a picture and a price but i'll have to get a picture of the auxillary ones tonight and add them to the advert above.
Just let me know if your interested.
Gary
smitsturbo hasnt mentioned them again after his post above so there still up for sale mate should you want them?
Gary
Gary
if ya still got em gary, im guessing i should take the coil and leads, cant run original twin coils for ever can I, stick em to one side, as will be seeing you in just over 3 weeks matey
