2wd or 4x4 brembos,brand new quaife thick wall atb, 4x4 leda 3way adjustables
twin plate clutch with flywheel £500
brand new quaife atb front diff in a thick wall casing never been on a car £1350
4x4 leda 3way adjustable with remote resivours bought from dave moss when he broke yum after £1700
front 4pot brembos calipers with 360mm grooved discs and pad with either 2wd or 4wd
brackets and bells also braided lines will fit under a 17" comp wheels £950
rear 4pot brembo calipers with 330mm grooved discs and pads with brackets and bells will need to use a hydraulic hand brake or use spot calipers to keep the hand brake cable £800
et25x8x18 comps with 225x40 toyo r888 there are a few marks on the alloys the 888 are basicaly new there escort cossie fitment £750
OMP 4litre electrical fire extingisher system with 6 nozzels 1 full roll and some cut bits of aluminium tubing all wireing control box and external push button £200
AP 4 paddle clutch plate not been used much £80
2wd rear drive shafts with new cv boots on £100
front drive shafts need new cv boots £50
4x4 prop £40
4x4 front hubs with new bearing fitted £100
new front drive shaft cv boots kit £40
baily oil breather tank including hoses £65
full 2wd samco hose kit including swirl pot and water temp fitting in the hose £120
rear diff cover that soild mounts the diff to the car with an oil pump so you can run an oil cooler on the diff £200
4x4 front prop £40
4x4 engine crossmember with steering rack £50
standard 4x4 front diff £50
2wd front hubs with new tcas with polybushed £60
wrc front diff surport bolts to the block and goes on the diff bolts into the sump with a rose joint £50
2wd rear beam with arms the arms have had the old bushes knocked out £60
fuel rail with -8 fitting brazed on £5
cossie rear abs sensor hardly had any use £60
amal valve £5
standard cossie fans £30
msd uprated cosworth fan switch £10 posted
forge dump valve had very little use £70
will post at extra cost or parts can be collected
my numbers 07716750693
will consider reasonable offers
will be add more though the week but any bits seen on the project thread that i aint listed yet pm me about or ring
