2wd cosworth parts prices
Old Oct 24, 2009 | 11:24 AM
andyuk's Avatar
andyuk
Default 2wd cosworth parts prices
right iam selling all my spares as i have no needs for them now, offers as i need them gone
steering column with barrel but no ignition switch £30
2wd prop £50
2wd manifold
2wd std lsd no casing or ring gear damage to spline £30
2wd rear diff plate cover £20
2wd front hub £ 30
turbo oil return pipe £5
turbo oil feed pipe£ 10
exhaust cams x2 £20 each
ahmed bajoo chip for stg 3 set up l6 ecu £50
2 bar map sensor like new never used £40
metal water feed pipe to matrix £8
2wd fans £40
set of std size pistons £60 with rings
2wd anti roll bar with poly bushs £40
Old Oct 25, 2009 | 08:58 PM
andyuk's Avatar
andyuk
bump
Old Oct 25, 2009 | 09:14 PM
smartrs's Avatar
smartrs
have you got a steering wheel coule ? top and bottom bit ?
Old Oct 25, 2009 | 10:08 PM
Olivera's Avatar
Olivera
I PM'd you mate. Let me now how much you'd want for the Grp A coil and 044 fuel pump.
Old Oct 26, 2009 | 06:56 AM
ally7th's Avatar
ally7th
woodhouse motorsport
pm'd
Old Nov 8, 2009 | 07:12 PM
andyuk's Avatar
andyuk
b b b b b bump
Old Nov 8, 2009 | 07:20 PM
smartrs's Avatar
smartrs
still looking for steering wheel plastics ???
Old Nov 8, 2009 | 07:54 PM
Mark 3D's Avatar
Mark 3D
Moderator
Need to state prices please as per the rules.
Old Nov 8, 2009 | 07:56 PM
bad boy rs's Avatar
bad boy rs
did the nms chip sell ?
Old Nov 8, 2009 | 08:00 PM
andyuk's Avatar
andyuk
Default yes
yes mate only the ahmed bajoo left
Old Nov 8, 2009 | 08:07 PM
MegaRST's Avatar
MegaRST
pm me price on head please and pics if poss
Old Nov 8, 2009 | 08:15 PM
turboRS's Avatar
turboRS
C16OSY
price of calipers and disks please mate. and also the -31 actuator.
wat condition are they in?
are calipers seized at all?
can collect as from brum myself!
Old Nov 8, 2009 | 08:53 PM
Barry R's Avatar
Barry R
just curious what spec is the bayjoo chip
Old Nov 9, 2009 | 07:18 PM
andyuk's Avatar
andyuk
Default spec
l6 ecu, 3 bar greens not sure on turbo t35 i think thats what i had run on it
Old Nov 9, 2009 | 07:33 PM
Mark 3D's Avatar
Mark 3D
Moderator
Thankyou
Old Nov 9, 2009 | 08:23 PM
Barry R's Avatar
Barry R
do you know wot size exh housing
Old Nov 9, 2009 | 08:39 PM
andyuk's Avatar
andyuk
Default std
std not sure maybe a 48
Old Dec 9, 2009 | 04:59 PM
andyuk's Avatar
andyuk
offers to nearest bump
Old Dec 9, 2009 | 06:56 PM
JamesH's Avatar
JamesH
door seals and rubbers £5 each
What seals and rubbers are they mate? What condition?
Old Dec 9, 2009 | 08:33 PM
andyuk's Avatar
andyuk
Default seals
door seals the ones that go around the inside to stop water getting in, boot rubber seal etc etc
Old Dec 9, 2009 | 10:55 PM
Rob Virgo's Avatar
Rob Virgo
ill have the four door (window) seals if they are in good nick and the ones that are visable on the out side of the windows,need the plastic rear triangles on the back doors the seals run into
rob v
Old Dec 10, 2009 | 05:47 PM
andyuk's Avatar
andyuk
rob v
only got the inners mate, just checked and no triangles, them outer window ones are hard to get mint ones
Old Dec 10, 2009 | 10:14 PM
smartrs's Avatar
smartrs
i'll have secound dip on them rubbers if rob dont want them , have you got the boot seal too ?
Old Dec 11, 2009 | 09:46 AM
andyuk's Avatar
andyuk
Default rub
door seals still avalible, and yes think i have a boot seal too,
Old Dec 11, 2009 | 11:00 AM
FQ200turbo's Avatar
FQ200turbo
you got pm
Old Dec 24, 2009 | 11:26 AM
2ndGear's Avatar
2ndGear
i will have have that lsd mate if you pm me deatils
Old Dec 24, 2009 | 06:47 PM
Rozvor's Avatar
Rozvor
I understood four pistons with the rings. Total price with shiping cots to Spain?
Old Dec 24, 2009 | 10:19 PM
CRAIG HAYTER's Avatar
CRAIG HAYTER
do you have a standard 205 block?
Old Dec 26, 2009 | 10:45 AM
EssexMikeSi's Avatar
EssexMikeSi
U got a pic of the loom please mate? and do u have a throttle body? if so how much please, cheers
Old Dec 28, 2009 | 04:09 PM
my-first-rst's Avatar
my-first-rst
tokey smurbo
you still got the actuator mate? how much posted? dont suppose its got the bracket with it too ?
steve
Old Dec 28, 2009 | 07:04 PM
busa bob's Avatar
busa bob
i'll have engine loom mate if you still got it? can i have contact number please to arrange collection
Old Dec 31, 2009 | 08:54 PM
andyuk's Avatar
andyuk
bump
Old Jan 3, 2010 | 12:25 AM
janvanv's Avatar
janvanv
www.rallyanarchy.com
bump
Hi Andy,
if you still have the 2 exhaust cams and they're standard cams I need them both.
They can be shipped to a UK address if sending them over here is too much bother,
please let me know.
Also need the turbo return pipe, and maybe if you have it a 2wd mudplate (the tin plate tween engine and bellhousing) and a 2wd starter.
And hell while we having such a nice productive chat, got any exhaust turbine housings?
Paypay card is burning a hole in my pocket!
Oh what side is the 2wd knuckle or hub? Don't follow your near side/off side so could you say drivers' or passenger side.... is it complete?
Old Feb 4, 2010 | 01:49 PM
andyuk's Avatar
andyuk
bump still got bits left, i dont want to chuck them,
MARKYMARKONE
Aug 20, 2015 12:55 PM
Aug 14, 2015 11:21 AM
Aug 14, 2015 07:29 AM
adam151082
Aug 11, 2015 04:50 PM
Old ford
Jul 31, 2015 06:50 AM
