big spec FRST breaking
Due to the state of my shell and the cost of getting it up to scratch I am breaking my fiesta rs turbo all parts available.
Here is the list I will add more as I remember more pics later i will take some pictures of the parts current condition all parts plus p&p
2.0L zvh eagle steel rods, Je pistons blocked machined to take another thrush bearing because of the heavy clutch had a rebuild 4000 miles ago
sitech racing head gasket
pumracing 45mm valve and ported head, Newman phase four cam with solid lifters and a spare set of inlet valves rebuilt 4000 miles ago-£1800 will split
GT25/40r dual roller bearing turbo with Simpson’s race exhaust tubular manifold t25 mounting plus down pipe for cvh head places turbo over gearbox with supporting bracket-£800 prov sold will split
Tube torque 3” exhaust system with 4” tail pipe-£70 prov sold
zoo spoon style inlet manifold with 45mm ram jets takes a cosworth throttle body-£130..... prov sold
cts BC gearbox stage two+ with 3.6 final drive done 4000 miles at low boost-£750
reco-prop uprated drive shafts very strong to work with the BC box-£180
zoo rose jointed adjustable lower arms can adjust camber and castor just changed the rose joints-£180 sold
zoo rose jointed rear beam with 240mm discs new golf mk3 calipersprov sold plus hand brake cable-£70 prov sold
Grs evo3 intercooler-£120 prov sold
Grs 520mm radiator with twin kenlowe fans-£70 prov sold
innovate xd-16 + innovate lc-1 wideband wide band XD-16-£140
Siemens 850cc injectors done 1500 miles-180
Aeromotive fuel regulator 13109 with modified EFI fuel rail-£70 sold
Cosworth Twin ignition coils with custom bracket-£70 sold
Cosworth management crank pulley and phase sensor with bracket-£50
Mk3 fiesta safety devices six point bolt in roll-cage-£210 prov sold
Cosworth loom by Ryan can run 36-1 or 4 point pick crank sensors and other extras all connectors are labelled-£275 sold
Avcr boost controller with a spare new map sensor-£170 sold
Auto meter 5” rev counter with shift light-£50
L8 ecu with a coil pack driver, msd closed loop, launch control, anti-lag and map for 850cc injectors, but high speed mapping needs completing-£390 sold
15” team dynamics Motorsport pro race 1.2 wheels- with R888 195-50-15 tires done around 840 miles-£300
Set of R888 205-50-15 tires done 600 miles-£120
Set of 17” wheel mania jade with 205-40-17-£160
Zoo Custom gearbox cradle with rally style engine mounts-£150 prov sold
Mk3 Granada 90amp alternator good upgrade for the mk3 fiesta-£20
Clutch assembly AP racing twin plate cover with 2 helix plates and modified Efi flywheel works in a BC or ibc bell housing 400Ibs torque capabilities-£300
Pair of recaros in red alcantara and black leather-£100 sold
Cosworth 4x4 calipers with 280mm grooved discs-£110
just cant be arsed thing is since my latest rebuild the engine behaved just the way i wanted who ever buys the engine is going to have a high reving power house zvh
sean
yeah your right christian takes alot of balls i am still being a bit slow to break her i've had the car 14 years spent thousand's but enough is enough
sean
sean
pm me an offer everything is done ready just to bolt up the top mount which is modded, i dont know if it will fit an escort,i dont know what the escort top mount looks like,
pm me
sean
