Massive clearout of bits and bobs
Apr 28, 2009 | 03:54 PM
going through my shelves today I have masses of odds and sods
crank senors,knock sensor,inlat manifolds,exhaust manifolds,engine brackets,front pully bolts,clips,pipes,pulleys,nuts and bolts,steering componets,brake parts,roll bars and clamps,rear axle parts,engine and gearbox mounts,
bascially shits loads of stuff,no matter how small please ask,all dirt cheap to clear
Apr 28, 2009 | 04:31 PM
looking for a t34 actuator bracket?
Apr 28, 2009 | 04:37 PM
escos rear arb with clamps ?
Apr 28, 2009 | 04:38 PM
Dya have a phase sensor for a 3dr bud,opened up the dizzy & its fubared
Apr 28, 2009 | 04:46 PM
Quote:
Originally Posted by
stevenebm
yep £15 delivered
Apr 28, 2009 | 04:47 PM
Cragrat
buy a new one mate,there only about £20 Matt Lewis is your man for one
KSA-Cossie
sorry I dont
Apr 28, 2009 | 04:50 PM
RS Specialist
thought so,think he might be getting sick of me ringing him now
Apr 28, 2009 | 04:56 PM
Apr 28, 2009 | 04:58 PM
RSLUBBY
good engine
sorry mate I aint got an engine in the place
Apr 28, 2009 | 04:59 PM
RS Specialist
sorry I dont
No probs pete.
Apr 28, 2009 | 05:09 PM
pete whats your paypal addy and i will go send the £15 as a gift so you dont recive charges
Apr 28, 2009 | 05:20 PM
stevenebm
ashfieldmotorsport@ukonline.co.uk
Apr 28, 2009 | 05:25 PM
hi,do you have rear abs sensors for 4x4 saph cossie?cheers col93saphcos
Apr 28, 2009 | 05:31 PM
col93saphcos
yes I should have but will have to cjeck the condition of the palstic housing as they split
by the way you still keepering on Glen Trusta
Apr 28, 2009 | 05:37 PM
payment sent mate.delivery details on the paypal bit.cheers matey.
hi do you have 2 wd engine mounts?
Apr 28, 2009 | 05:38 PM
pete by any chance do you have a 4x4 water return from the turbo?
Apr 28, 2009 | 05:55 PM
Leighton rs
the alloy or rubbers ones I have both
which one top or bottom I have both
Apr 28, 2009 | 06:35 PM
would be cool if you could let me know about sensors,no left there about 3yr now,just over the glen into glenclova,rottal lodge,still keepering but with no hassles,hope alls still going fine with you,been a while since spoke to ya,lol,thanks col93saphcos
Apr 28, 2009 | 06:46 PM
pete im after the rubbers that sit on top of the fuel pump cradle on the corners if you know what i mean on a 4wd saff, the ones that when the cradle gets bolted up they touch the boot floor, have you got 2 by any chance??
thanks gaz
Apr 28, 2009 | 08:29 PM
got any boost hoses I'm after a blue turbo to cooler on a 4x4 saff prefer samco to match the rest, T34 and 500 type cooler if it matters.
Apr 28, 2009 | 08:36 PM
pete would u have a EsCos fuel pump std one?£?
Apr 28, 2009 | 09:23 PM
3dr parts
Hi after a 3dr rear end set up to get powder coated, also any 3dr panels. What you got
cheers simon
Apr 28, 2009 | 09:57 PM
Do you have a T5 Gearbox speedo drive?
Cheers Rich
Apr 28, 2009 | 11:50 PM
.63 exhaust housing for a T34?
Apr 29, 2009 | 11:05 AM
A pair of cheap 2wd front struts please. Doesn't have to be anything flash as long as they have enough damping to pass an MOT and are complete with springs.
Apr 29, 2009 | 02:01 PM
crank sensor braket
fuel pump cradle
3 bar map
ign amp/bracket
amal valve
t3
t5 cross member
rad switch
all i can think of now
rob
Apr 29, 2009 | 02:07 PM
maybe ,
2wd rear calipers.
need photo to check part,cant remember what they look like exactly...
rob v
Apr 29, 2009 | 02:08 PM
Got any
- Green injectors
- 3 bar map sensor
- 330 bhp chip
Apr 29, 2009 | 03:08 PM
cossietim
Got any
- Green injectors
- 3 bar map sensor
- 330 bhp chip
none left sorry
Apr 29, 2009 | 03:09 PM
Rob Virgo
maybe ,
2wd rear calipers.
rob v
got plenty of them
Apr 29, 2009 | 03:10 PM
stu21t
sorry no
Sonic Boom
Cheers Rich
sorry,no
siscossie
cheers simon
yep got that,call me
Apr 29, 2009 | 03:11 PM
jemis
I should have the odd hose kicking about as i have a box full of oddments give me a call Friday morning
Apr 29, 2009 | 03:32 PM
*** Sierra RS Custard ***
how much delivered for a pair of good condition crank sensors?
Apr 29, 2009 | 03:48 PM
Chip
£23 should cover it
Apr 29, 2009 | 03:57 PM
pete i know this is like the smallest part ever but im struggling to find one.looking for the adaptor that screws in to a t34 turbo for the oil feed.
