Gearbox oil draining and oils
Old 24-06-2018, 08:27 AM
Russ6334
Russ6334's Avatar
Default Gearbox oil draining and oils
Then I assume this is gearbox fill
One assumes this is the transfer box drain?
Is this on the left gearbox drain? And on the top right transfer box fill?
hi all
you’ve all been really helpful with other issues and just moving on to the next!
drained my “gearbox and transferbox” I say that cause I’m not sure what I’ve drained at the rear of the gearbox I’m assuming is the transfer box and what looks like a gearbox is obviously the gearbox? Clear as mud?
there are what look like two drains on the transfer box? But only one fill? Also the gearbox looks like a fill but no drain?
The photos are easier to explain!
Old 24-06-2018, 08:39 AM
Russ6334
Russ6334's Avatar
Are these good enough for diff and gearbox, again not to be rude don’t need to know personal choice just want to know if this is ok or will cause damage
The reason I ask is that the transfer box has two drains very close to each other which seems odd just don’t want my car running dry
have taken out exactly 2 litres
also the oil is red which I assume is ATF though hasn’t got the same smell it’s almost odourless
would the photo attached of ATF be good enough? I don’t need to know personal choice just want to know if it’s acceptable.
Old 24-06-2018, 08:57 AM
I was told to use atf in the transfer box but others on here have said not.
There is a full hole and a drain hole.
Old 24-06-2018, 08:59 AM
Russ6334
Russ6334's Avatar
I get there is a fill and drain hole! Did the photos make sense as which is which
Old 24-06-2018, 09:03 AM
Yes, transfer drain where you showed it and
Fill for box on side, drain at bottom and just fill TIL it spills out
Old 24-06-2018, 09:06 AM
Russ6334
Russ6334's Avatar
So on all the photos I named the film and drain correctly then?
What about the oils? All ok to use?
Old 24-06-2018, 12:10 PM
Russ6334
Russ6334's Avatar
All done
thanks
Bailes1992
24-12-2013 12:02 PM
oilman
Trader Parts for Sale.
10-02-2010 09:02 AM
oilman
05-10-2009 11:33 AM
Quick Reply: Gearbox oil draining and oils
