2wd cosworth/saph cosworth steering/handling
Old Aug 2, 2016 | 07:38 PM
The 6 degree beam reduces the change of suspension geometry during suspension movement, they were used in the BTCC back in the day. MK motorsport does one with extra adjustability. It is all about dealing with the compromises Ford built in due to cost and knowledge at the time.
I am about to fit one and I understand it makes a large improvement.
On a road car thicker and stiffer is often the enemy. It is control, suppleness and integrity of the geometry set up that makes a good road car...that and then good tyres.
Old Aug 2, 2016 | 07:41 PM
doga-ot's Avatar
doga-ot
Originally Posted by Harris.
Ahmed springs and Koni's is the set up I had and to be fair I found it excellent . Set your Koni's half way not fully hard . I Also had powerflex bushes back and front .
Change your diff mount ,sounds odd but my 3 door drove totally different after fitting the MSD item . Ł120,and the best Ł120 id spent on the car .
If you have fitted power flex bushes id avoid coilovers if the car is for road use , had mine on for around a week and the ride was just to hard and I wanted to keep my teeth . How ever there adjusted they dont have any give .
Also , what tyres are you using and what size wheels ?
I have a poly diff mount and as you say firms up the rear and makes a world of difference
Old Aug 2, 2016 | 07:45 PM
doga-ot's Avatar
doga-ot
I know Marks beams are the bollox i know a few people who have had them, but thing is even if i wanted one right now Marks turn around is really really slow
Old Aug 2, 2016 | 07:48 PM
Others are available. Mark is slow on some stuff but speak to him on the beam. Mine is bespoke as it has been made to take the supra diff without any fitting kit, plus to take his bladed anti roll bar (different mounts) and then powder coated to my spec. It has been less than 4 weeks start to finish and he found me a donor beam.
MT may have one on the shelf.
Old Aug 2, 2016 | 08:04 PM
doga-ot's Avatar
doga-ot
Pm me bud or whats app how much it cost cheers i know mine be cheaper cos just want standard 6degree beam for now!
Old Aug 2, 2016 | 08:34 PM
Before doing the 6 degree rear beam I would go on the lookout for 3dr hubs. Imo they do more then the beam.
Old Aug 2, 2016 | 08:41 PM
I have not heard this before, why didn't ford just use them?
Old Aug 2, 2016 | 08:50 PM
the problem with 3dr hubs is they make the car feel unstable driving at high speed on the motorway .its why ford changed them on the saff
Old Aug 2, 2016 | 08:54 PM
steppy's Avatar
steppy
Isn't that the reason why ford changed to the h14 arb for the extra degree of caster over the h13 to combat the straight line stability on the later 3 doors and rs500 and offered it as a recall for early cars if the owners chose, then carried the arb over to the saph as it was a success, the hubs on the 3 door were for homologation purposes iirc, i have heard stories of the very first saphs using up the left over 3 door hubs on the production line
Old Aug 2, 2016 | 09:05 PM
better explanation steppy,as i believe the castor was the problem but i thought it was part of the hub issue
Old Aug 2, 2016 | 09:06 PM
doga-ot's Avatar
doga-ot
3dr hubs do make big difference hense they are hard to get hold of now they give more adjustability/camber/caster
Old Aug 2, 2016 | 10:42 PM
Your making me want a set of 3dr hubs lol
Old Aug 3, 2016 | 05:48 AM
At standard ride height the 3dr hubs might make the car feel unstable and the Sapph hubs will probably be the best setup. But since most of the cars have been lowered, the Sapph hubs place the roll center way too low and the 3dr hubs place the roll center at the right location.
I also believe the 3dr hubs give a better scrub radius or something like that. But they don't do anything for adjustability, camber or castor.
When I changed the standard Sierra (so not even Sapph cossie) hubs for 3dr hubs the car felt completely different.
Old Aug 9, 2017 | 08:46 AM
Jim Green's Avatar
Jim Green
Don't forget, if you fit 3dr hubs to a Sapphire you need to get the front geometry set up for a 3dr otherwise the handling is a death trap.
Old Aug 9, 2017 | 12:32 PM
What's the difference in set up between the two?
I thought the only thing to adjust is tracking.
Got a set of 3 door hubs for my 5 door and want to get it right!
Old Aug 9, 2017 | 04:48 PM
Mark any wheel alignment place who knows there stuff will ask u what u require and set it up like that...
Lucky for me i have a mate who has been doing it for 30years and if he dont know then nobody does.
Old Aug 9, 2017 | 05:42 PM
There is no special setting for a 3dr. Just have the tracking set to 2 mm toe in, or about 0 degrees and 8 minutes per wheel.
Old Aug 10, 2017 | 09:58 AM
Jim Green's Avatar
Jim Green
I know Mike Rainbird put up the settings on here many years ago, might take some finding, but worth the search if you find the settings he posted.
Some info on these links :
https://passionford.com/forum/genera...y-setup-s.html
https://passionford.com/forum/ford-s...-s-differ.html
https://passionford.com/forum/genera...h-fitting.html
It's times like this when people like Mike Rainbird were invaluable.
Old Aug 11, 2017 | 07:07 AM
The settings for fast road use advised by Mike are the same for all Cosworths, 2wd and 4x4:
Front:
2 mm toe in (total)
-1.5 degrees camber
3.5 degrees castor
Rear:
3 mm toe in (total)
-1.5 degrees camber
For track use you can add more camber, but the rest stays the same.
Old Aug 11, 2017 | 09:33 AM
dose the mk beam not have different settings. I was under the impression the arms are different and you use the settings he says? maybe wrong but im sure I read that on here
Old Aug 11, 2017 | 10:18 AM
The toe adjustment on the MK beams is different and very nicely made. It is on the inner pivot and therefor doesn't change the distance between front and rear wheel much, unlike the ones where the outer pivot is adjusted. But the way of adjustment doesn't make a difference for the settings to use.
Old Aug 11, 2017 | 02:25 PM
Mark MK sent me these pics recently and said they are adjustable roll centre and adjustable TCAs. Would these do the front end? I have the WRC hubs and arb / comp struts.
Old Aug 11, 2017 | 03:12 PM
Any idea on price Toby?
Old Aug 11, 2017 | 03:14 PM
That's nice. It's exactly what I posted here a couple of months ago. https://passionford.com/forum/genera...adjusters.html
Old Aug 11, 2017 | 05:08 PM
I don't know but I will find out.
Old Aug 11, 2017 | 05:46 PM
I texted him
Ł350 plus vat plated finish. Complete.
He sent me a pic of 10 pairs waiting plating.
Just to be clear, I have no affiliation with MK apart from paying off his mortgage with all the bits I have bought lol. I do not get any freebies (he's from Grimsby - they don't do freebies)
Old Aug 12, 2017 | 07:36 AM
Lol cheers for finding out, they look a lot better than the normal adjustable tcas due to you being able to replace the ball joint separate.
Old Aug 12, 2017 | 07:38 AM
What's the little round bit for just to the left of the arb connection?
Old Aug 12, 2017 | 09:36 AM
I've a friend with a saff on an mk beam set to the recommended settings off here I'm sure there the rainbird settings. I've not been in the car but it's meant to be awful now really nervous I'm told and wants to go sideways all the time. Also runs none coil over suspension so not really hard suspension set up iver
Old Aug 12, 2017 | 09:43 AM
Then I doubt that the settings are good. Unless there is play in the joints in the beam all should be good. Mike's settings are independent on the type of beam, even if it's 6 degree or standard. Actually Mike's settings (apart from the camber) are the same as what Ford put in the Group N and A manual for the Escort Cosworth.
Old Aug 12, 2017 | 09:46 AM
Beam was new set up by a guy who sets up track cars I'm told. Settings taken off here. Not been in it myself I've the same beam but mines off the road waiting for my engine. I'll use the settings my tuner recommends and let him set it up once back so will be interesting to see how it drives
Old Aug 12, 2017 | 09:47 AM
It looks like for connecting a bladed arb.
Old Aug 12, 2017 | 10:17 AM
Yes, that is correct.
I have the bladed arb front and rear...not tried the rear yet but it is on and set to full soft at moment. I am going to swap to 160 and 180 lb springs on the rear and see what that is like as I have 200 at moment but the car is so light I think they are too stiff. At the end I will get new Shox.
Old Aug 12, 2017 | 10:23 AM
I had a feeling that's what it's for, nice one a reasonably price setup as going full billet wrc is a bit much.
Old Aug 12, 2017 | 10:35 AM
FLAT TRACK's Avatar
FLAT TRACK
hi
it has to be settings or something else with the car
Old Aug 12, 2017 | 11:12 AM
Originally Posted by FLAT TRACK
hi
Yep must be I know others with the beam who rate it as one of the best mods done thats why I have it in my car
Old Aug 12, 2017 | 12:04 PM
FLAT TRACK's Avatar
FLAT TRACK
HI ADAM
yes they use all the same bearings ,adjusters and pin material as the billet wrc ones
Old Aug 12, 2017 | 02:57 PM
Thanks Marc, do you do compression struts to suit or are burton power ones ok for your tca?
Old Aug 12, 2017 | 07:26 PM
Also do they make the roll centre like the 3dr hubs or does nothing change? Can they be anondised?
Old Aug 13, 2017 | 08:31 AM
You would need to powder coat them as they are steel, anodise would only work on ally.
They are normally plated but that does tarnish very easily. You could have them painted but you would want proper paint like a body shop as rattle cans would not last long.
I do not think the MK compression struts that I run would work with these as it is a totally different fitting. If you run comp struts you would need the bladed arb imo although I know some people say you don't need arb with comp struts.
