Facelift dash
Old May 23, 2009 | 10:12 AM
timster's Avatar
timster
Default Facelift dash
Can anyone help me out? the hood part of the dash has come away from the main part by the twin vents in the centre.What actually breaks on these? some sort of clip arrangement by the looks of it
Old May 24, 2009 | 12:29 PM
timster's Avatar
timster
Anyone?
Old May 24, 2009 | 02:26 PM
Paul_RS's Avatar
Paul_RS
Any pics of the problem mate? May make it easier to see whats wrong
Old May 24, 2009 | 03:45 PM
timster's Avatar
timster
The "hood" part of it seems to have come away from the main dash by the vents in the centre,seems as if it wants to clip into something
Old May 24, 2009 | 03:56 PM
KSA-Cossie's Avatar
KSA-Cossie
I thought it was one piece ? Mine's a facelift dash but can't remember.
Old May 24, 2009 | 04:32 PM
timster's Avatar
timster
This is the hood part of the dash
This is the problem area
This is whats protruding from the dash and looking at it there seems to be some sort of metal clip in the dash
Old Apr 24, 2017 | 07:45 PM
dojj's Avatar
dojj
Resident Wrestling Legend
there is a hole there, the plastic bit that's snapped off is straight as in this picture
the metal tab that it clips into is a 3 pronged affair and when you've fixed this bit unscrew it from the inner dash and fit it to this bit, then fit the whole thing back in again
Old Apr 24, 2017 | 09:02 PM
timster's Avatar
timster
Hi Dojj thanks for the reply, before I strip it down I'll need to remove the centre vents to re-attach the clip? I'll repair the dash or if not find a good second hand one
Old Apr 25, 2017 | 06:37 PM
dojj's Avatar
dojj
I did it without using a small bit and a ratchet spanner
Old Apr 26, 2017 | 03:06 PM
Mines a bit loose there too. Top info this I will have a go at fixing mine.
Old Jul 8, 2018 | 10:53 AM
timster's Avatar
timster
Hi Dojj have you had any success repairing these?
Old Jul 9, 2018 | 07:28 PM
dojj's Avatar
dojj
It was a LONG time ago mate, I drilled a few holes all around the area and then used lashing of fibreglass and gunk to make the fixing much bigger
Then I started to sand it down until it was the same sort of size
Old Jul 13, 2018 | 09:16 PM
timster's Avatar
timster
After considering buying another second hand part I drew up and made a plastic clip which I glued to the inside of the dash to replicate the original feature. Started fitting it all back tonight and it works a treat, should be stronger than the original design too
Fordmad!
Sep 29, 2015 07:03 PM
IainRS1700T
Sep 25, 2015 06:44 AM
morg65
Escort MK 5 / MK 6
Sep 23, 2015 03:19 PM
imnoteasy
Sep 7, 2015 09:26 PM
