My New M.A.D Escort Cosworth
Old Feb 5, 2017 | 07:59 PM
  #361
Forgot to add the Stack AFR gauge will be hard wired in to the new ECU when fitted.
Old Feb 18, 2017 | 03:44 PM
  #362
Todays random pics I took after afew months of not looking under the bonnet.
Old Feb 18, 2017 | 04:28 PM
  #363
Looks great. I had mine out today, really pleased apart from it jumping out of 4th still. I loosened the bolt on the quick shift which Mark thought might help but it didn't...I think it needs a new selector fork and maybe. A standard shifter to protect the fork???
Old Feb 18, 2017 | 05:17 PM
  #364
Mad_Mat's Avatar
Mad_Mat
New Owner
love your car dude amazing spec. Heres to another fun summer
Old Feb 18, 2017 | 07:19 PM
  #365
Get the grinder out
Old Feb 19, 2017 | 05:02 PM
  #366
Can't see the quicker shifter doing that. Know someone that used that setup hard on track with no issues. Keep us posted on your findings.
Originally Posted by smiley
Get the grinder out
Forgot this pic
Old Feb 19, 2017 | 05:14 PM
  #367
Bara's guy thinks the quick shift is hammering in 4th too hard and bending the selector, the said the std one has more play
Old Feb 19, 2017 | 05:17 PM
  #368
Does it pop out of 4th ever time?
Old Feb 19, 2017 | 06:53 PM
  #369
All the time on over run
Old Mar 18, 2017 | 10:07 AM
  #370
Picked up the perfect set of wheels this morning 18" Escort Cosworth rep wheels.
Old Mar 18, 2017 | 05:57 PM
  #371
They will look great on the car
Old Mar 18, 2017 | 08:41 PM
  #372
Nice mate
Old Mar 22, 2017 | 09:38 PM
  #373
New wiring loom few relays and connectors to fit to the wiring loom when its fitted in the car.
Old Mar 23, 2017 | 07:54 AM
  #374
Looking good
Old Apr 1, 2017 | 03:11 PM
  #375
Wiring loom to be fitted next week
Wheel clearance is good swapping tyres off the TH's next week
Old Apr 1, 2017 | 03:36 PM
  #376
Mondi-DZK's Avatar
Mondi-DZK
Wow, 2 great sets of wheels. Very hard to make a choice. Luxery problems
Old Apr 1, 2017 | 04:19 PM
  #377
I like the comps best.
Old Apr 1, 2017 | 04:31 PM
  #378
Thats why TH's will be staying both my favourite set of wheels on a Escort Cosworth
Old Apr 3, 2017 | 04:10 PM
  #379
Fuel swirl pot removed for fuel temp sensor and exhaust down pipe to have 2 more bungs welded in for EGT and closed loop bosch sensors to be fitted.
Autronics Ecu removed & old wiring loom
Losing the waste spark kit being replaced with coil on plug.
More bits going that won't be need with the new ECU
Fuel pressure sensors for Stack gauge and Emtron ECU sensor going in to the fuel rail.
Emtron oil pressure ECU sensor will be going where the orignal factory one is fitted.
New wiring loom fitted through bulk head all needs connecting up.
Old Apr 3, 2017 | 04:17 PM
  #380
Wow really interesting stuff a lovely car.
Old Apr 3, 2017 | 06:19 PM
  #381
What coil on plugs are you using ?
Old Apr 3, 2017 | 06:26 PM
  #382
I imagine they will be the Toyota ones.
Old Apr 3, 2017 | 06:30 PM
  #383
Honda Type R coil packs.
Old Apr 5, 2017 | 06:00 PM
  #384
Fuel swirl pot bung weld in and fuel temp sensor wired up direct to the ECU. Fitted exhaust downpipe had 2 more bungs welded on accidentally deleted the pic theres 3 bungs in total. AFR for Stack gauge, EGT for Stack gauge & closed loop sensor direct to ECU. Rewrapped the downpipe with new black heat wrap.
Fuel pressure sensor fitted which is going direct to ECU
Waiting on the fitting for here senor for Stack fuel pressure gauge will go here
Coil packs fitted and most of the wiring loom connected
Old Apr 5, 2017 | 06:45 PM
  #385
Soooo clean. Looks amazing
Old Apr 5, 2017 | 07:22 PM
  #386
Tev's Avatar
Tev
love this car!! so clean and tasteful mods!!
The only thing that im not sure about is the 18 inch escos wheels, they are let down by the center caps!! they look stunning but the caps never seem to fit correct
that said its just my opinion which is worth fook all ha
Keep up the good work fella
Old Apr 5, 2017 | 07:24 PM
  #387
3doorcozmess's Avatar
3doorcozmess
good work love this car.
are you planning on increasing the bhp?
this car must be the safest 500bhp engine with all the sensors your adding and emtron upgrade.
si
Old Apr 5, 2017 | 07:47 PM
  #388
These are a remark of the 18" wheel that was done this year the caps do sit better than the original 18" wheels.
si
Not looking for any more but if it picks up more just means it will run abit less boost. Just looking at adding more boost around low and mid range with the new ECU.
Multi throttles bodys should be going on next year and if it picks up more horse power it will be capped at 530ish bhp.
Old Apr 7, 2017 | 05:16 PM
  #389
Fitting for fuel rail sorted.
The Cossie wheels look massive compared to the Comps both wheel 18" Comps are 8j Cossies are 9j.
Tyres swapped over
Old Apr 7, 2017 | 06:39 PM
  #390
9 is a wide rim...how do they drive?
Old Apr 7, 2017 | 08:35 PM
  #391
Should know in the next few days the wheels aint fitted yet.
Old Apr 8, 2017 | 02:02 PM
  #392
Wheels fitted
Old Apr 8, 2017 | 06:18 PM
  #393
Don't fit them 5v sensors direct to the block or fuel rail, the vibrations will kill them, been there done that.
On my rally car i monitor what you have here and more. The sensors need to be away from the NVH, small pipe runs from the engine and clip the sensor to something soft.
They are not cheap, no matter what spec they still die.
Old Apr 8, 2017 | 06:43 PM
  #394
Looks good on them
Old Apr 8, 2017 | 08:56 PM
  #395
Will keep that in mind
Old Apr 10, 2017 | 08:13 PM
  #396
Underside all put back together.
Will need a new crank pulley one I've got fitted was put on when the Autonics was fitted 2 lug crank pulley. Will be getting a MK Motorsport 36-1 crank pulley timing is being affected when the car was started up today.
New crank seal and cambelt when pulley is off and mounting sensors remotelty after speaking with Mark today hes never seen any fail but does agree it limits the issue.
Old Apr 10, 2017 | 08:21 PM
  #397
Looks beautifully presented
Old Apr 11, 2017 | 05:48 AM
  #398
Out of interest what's the need for adding a fuel temp sensor buddy?
Old Apr 11, 2017 | 07:01 AM
  #399
Mark Shead's Avatar
Mark Shead
fueling changes from cold to hot fuel so it's a extra safety feature.
Mark
Old Apr 11, 2017 | 07:02 AM
  #400
I think that the Emtron can control the speed it runs at with the right pump. I would like the ecu wired to fuel pressure so that if it begins to fail it would cut power to stop the car running lean under boost.
You can also benefit with checking fuel temp to ensure the fuel system is not overheating the fuel.
