WRC breather kit, who's best?
Old Jan 1, 2017 | 05:23 PM
BRAMMER's Avatar
BRAMMER
Default WRC breather kit, who's best?
As per title looking at changing setup to a wrc or what ever is available better than the spec r setup I currently have
Old Jan 1, 2017 | 06:23 PM
I thought spec r was the best, what is wrong with what you have?
Old Jan 1, 2017 | 06:28 PM
I would have said x power made a good wrc one chris
Old Jan 1, 2017 | 06:45 PM
Spec-r do a twin pot system designed by mark I think that breathes from rocker both sides on the block returns to the sump via a one way valve and vents to atmosphere. Not cheap plus it sits wear the battery lives
Old Jan 1, 2017 | 08:56 PM
lee2cossies's Avatar
lee2cossies
Good question I'm after one too as my set up is no good.
Old Jan 1, 2017 | 09:20 PM
When you guys say the systems you have are no good, what makes you say this?
Old Jan 1, 2017 | 09:56 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
I had the twin pot Spec-r system it was designed originally for my car to cope with 850+bhp it worked when previous systems did not. If you want better fit a dry sump system then you don't require a breather system.
Old Jan 2, 2017 | 02:33 AM
lacey's Avatar
lacey
That is not correct
On a dry sumped turbo engine you will
Require a breather as you will get blow
By
Old Jan 2, 2017 | 02:35 AM
lacey's Avatar
lacey
+1
But I was informed that the
Wrc breather does have its limits
It's the tidiest set up
Old Jan 2, 2017 | 03:53 PM
Hasn't Will Pedley designed a WRC spec breather system.I did hear there were positive results but not sure on the limits of that system hp ways.
Old Jan 2, 2017 | 05:15 PM
grcossie's Avatar
grcossie
Originally Posted by lacey
+1
It doesn`t keep up with bigger volume engines.
Old Jan 2, 2017 | 05:21 PM
I think they can cope upto 450bhp
Old Jan 4, 2017 | 08:01 PM
cossiedave's Avatar
cossiedave
Had a wrc one on my escos up till 670 bhp then blew oil out got a spec-r twin pot now all good so far
