Focus ST225 gearbox vs ST220 gearbox!
Old Nov 13, 2016 | 04:40 PM
ROI354's Avatar
ROI354
Default Focus ST225 gearbox vs ST220 gearbox!
Hi guys, apart from different ratios is there anything stopping me putting the internals of a Focus ST box into the casing of an ST220??
Thanks.
Old Nov 14, 2016 | 10:32 AM
Bailes1992's Avatar
Bailes1992
Aren't they completely different boxes? From what I remember my Fathers ST220 had an MMT6 box with reverse in the top left and his T5 had reverse in bottom right?
Old Nov 14, 2016 | 12:07 PM
Rowe's Avatar
Rowe
Skint
the ST225 box is an M66. I doublt the internals will be transferable
Old Nov 14, 2016 | 01:24 PM
wayne thomas's Avatar
wayne thomas
Can't be done mate, they are completely different.
Old Nov 15, 2016 | 04:57 PM
ROI354's Avatar
ROI354
Thanks guys. Do you think the whole Focus box would bolt up to the V6?
Old Nov 15, 2016 | 05:45 PM
Rowe's Avatar
Rowe
Skint
Probably not. It's a Volvo engine so will most likely be a completely different stud pattern and shaft spline.
Can't you just replace it with a standard box?
Old Nov 15, 2016 | 06:44 PM
ROI354's Avatar
ROI354
But the ST220 has an MMT6 and the Focus ST has a 6MTT450 correct? From what I can gather they're essentially the same.
Old Nov 15, 2016 | 07:09 PM
Rowe's Avatar
Rowe
Skint
As I've already mentioned, the Focus is a M66 gearbox....
Old Nov 15, 2016 | 07:16 PM
RIB1122's Avatar
RIB1122
you can change the ratios in a st220 box
Old Nov 17, 2016 | 05:19 AM
3i Jim's Avatar
3i Jim
Focus st225 gearbox.
Mondeo st220 gearbox. They are both completely different and I very much doubt the internals are interchangeable. Why do you want to use an st225 gearbox over the Mondeo's?
